Jeep Wrangler Dome Light Mod
If you’re the owner of a Jeep Wrangler, you may have experienced some frustration with the interior dome light. For those not in the know, removing the doors on a warm day or for a bit of fun can lead to a dead battery. This happens because the Wrangler’s light stays on unless the fuse or light are removed, or a custom shutoff switch is added — at the expense of troublesome wiring. You could say it’s a Jeep Thing. [Tim Nummy] offers a solution with minimal modifications.
First off, pop the switch out of the door and set it aside. As a replacement, [Tim Nummy] has managed to salvage a door light switch from an old Mercedes. In addition to the same momentary-off function as the Wrangler’s stock switch, the button on the new one can be pulled out and locked for a secondary off position. Many machines and appliances use this same type of switch in their safety interlocks as a service position. [Tim] didn’t want to cut apart the wiring in the Wrangler in case something goes awry down the line, so for now he has filed down some spade terminals to slot into the Mercedes plug. He’s also 3D printed a nut to nicely secure the new switch in place. Check out his how-to video after the break!
Continue reading “Jeep Wrangler Dome Light Mod” →
Dome Light LED Retrofit
One of the bulbs in the dome light of [Pete’s] car burnt out. These were a bit hard to get at for replacement so he thought he’d try something that would last longer, and have no problem standing up to the vibrations that go along with automotive electronics. But plug-in LED replacements cost more money than he was willing to spend. Luckily there was a dollar store next door to the auto part shop, so he bought three LED touch lights for the dome and cargo bulbs.
After cracking them open he found that the LEDs were wired in parallel. He needed to put these in series in order to take advantage of the voltage drop. After de-soldering the bulbs he measured the characteristics of one, then calculated the voltage drop and resistor value using a worst case scenario of 14V to avoid damage to the light when the engine is revving high. From there he cut the traces on the board and rewired them. The reworked module fits nicely and as you can see in the image, gives a more pleasing light color than the orange of the stock bulb.
