Admit it. If you haven’t created your own little programming language, you’ve probably at least thought about it. [Muffed] decided to create a unique — and sweet — programming language that uses M&M (or, at least, M&M-like) candies as the building block of programs.
If this sounds strange, it is because, honestly, it is. It all started when a packet of GEMS (the Cadbury’s version of M&Ms) spilled and randomly fell in the shape of an arrow. There are only six symbols corresponding to the colors in a package. You create your program by arranging the candies and creating a digital image of the result. In practice, you’ll probably use ASCII text to represent your candy layout and let the compiler render the image for you.
The main way of encoding things is by the number of colored candy pixels in a row. So three blue morsels in an opcode, while four is a different opcode. Red candies encode integer literals with one candy being zero, two being one, and so on. Blue indicates control flow, green candy handles variables and stack operations, yellow is for math, and so on.
