Water Cooling The MacBook Neo Laptop To Double Gaming Performance
Recently [ETA Prime] felt a bit underwhelmed by the raw performance of his MacBook Neo when it came to running for extended periods under full load, such as when gaming. Thus the obvious solution is to mildly over-engineer a cooling solution that takes care of issues like thermal throttling.
The Apple MacBook Neo with its repurposed iPhone 16 SoC seems to have leaned hard into answering the question whether a smartphone can be a good general purpose personal computer. Ignoring the lack of I/O, it’s overall not a bad SoC for a laptop, but like when you try to push the CPU and GPU on a smartphone, they do get pretty toasty. Due to the minimalistic cooling solution in the MacBook Neo it’ll easily hit the 105°C thermal throttle limit.
Technically the ‘heatsink’ for this laptop is the aluminium case, as the SoC is coupled via a thermal pad to the case. This doesn’t leave a lot of space and the case will heat soak pretty fast, while also making retrofitting a cooling solution a challenge.
Continue reading “Water Cooling The MacBook Neo Laptop To Double Gaming Performance”
The top surface of a laptop cooler is visible. It consists of a black plastic mesh with thirteen fans visible behind it, with a blue backlit screen at the bottom of the cooler. There is blue LED backlighting behind each fan, and around the border of the cooler.
Making A Smarter Laptop Cooler
[Bogdan Micea] uses a laptop cooler, but was a bit annoyed that his cooler would run at the same power no matter how hard the laptop was working. Rather than keep adjusting the cooler’s power manually, he automated it by installing an Arduino Pro Micro as a controller in the cooler and writing a Rust controller application for his computer.
[Bogdan]’s cooler is controlled by four buttons, which can have different functions depending on how long they’re pressed. After mapping out their functionality and minor quirks, [Bogdan] soldered four transistors in parallel with the buttons to let the Arduino simulate button presses; another four Arduino pins accept input from the buttons to monitor their state. The Arduino USB port connects to the cooler’s original USB power input, so the cooler looks superficially unchanged. When the cooler starts up, the Arduino sets it to a known state, then monitors the buttons. Since it can both monitor and control the buttons, it can notify the computer when the cooler’s state changes, or change the state when the computer sends a command.
On the computer’s part, the control software creates a system tray that displays and allows the user to change the cooler’s current activity. The control program can detect the CPU’s temperature and adjust the cooler’s power automatically, and the Arduino can detect the laptop’s suspend state and control power accordingly.
Somewhat surprisingly, this seems to be the first laptop cooler we’ve seen modified. We have seen a laptop cooler used to overclock a Teensy, though, and a laptop’s stock fans modified.
Teensy 4 Pushed To The Limit With 1 GHz Overclock
Do you need a microcontroller that runs at 1 GHz? No, probably not. But that didn’t stop [Visual Micro] from trying, and the results are pretty interesting. Not only did the plucky little chip not cook itself, it actually seemed to run fairly well; with the already powerful microcontroller getting a considerable boost in performance.
According to [Visual Micro] the Teensy 4.1, which normally has its ARM Cortex-M7 clocked at 600 MHz, can run at up to 800 MHz without any additional cooling. But beyond that, you’ll want to invite some extra surface area to the party. It’s easy enough to cut a chunk out of an old CPU/GPU cooler and stick it on with a dab of thermal compound, but of course there’s no shortage of commercially available heatsinks at this size that you could pick up cheap.
Cutting a custom heatsink.
With the heatsink installed, [Visual Micro] shows the Teensy running at around 62 °C during a benchmark. If that’s a little hot for your liking, they also experimented with an old laptop cooler which knocked the chip down to an impressive 38 °C while under load. It doesn’t look like a particularly practical setup to us, but at least the option is there.
[Visual Micro] unfortunately doesn’t go into a lot of detail about the benchmark results, but from what’s shown, it appears the overclock netted considerable gains. A chart shows that in the time it took a stock Teensy to calculate 15.2 million prime numbers, the overclocked chip managed to blow through 21.1 million. The timescale for this test is not immediately clear, but the improvement is obvious.
Even at the stock 600 MHz, the Teensy 4 is a very powerful MCU. Especially after the 4.1 refresh brought in support for additional peripherals and more RAM. But we suppose some people are never satisfied. Got a project in mind that could benefit from an overclocked Teensy? We’d love to hear about it.
Continue reading “Teensy 4 Pushed To The Limit With 1 GHz Overclock”
Removable Laptop Water Cooling
[Bard] just sent me a nice water cooling hack. He built a simple water cooling system that can be manually inserted into the cooling system of his laptop. He wanted it for watching movies sans annoying fan noise. He soldered the parts together using a stove instead of the standard propane torch. Necessity is definitely the mother of invention. I hope he relocates the water cooling supply. When he wants to go mobile, he just unplugs the cooling fins.
