The greatest invention relating to music in the 20th century was multi-track recording, for which we have Les Paul to thank. The second greatest? Non-linear editing and Pro Tools. For some bizarre reason, we have Ricky Martin to thank for that because Livin’ La Vida Loca was the first #1 single to be recorded and mixed entirely in Pro Tools.
The third greatest invention in recording since Edison is the plugin. If you’ve already got a computer sitting in front of you, you’ve got every instrument ever made. All you need is a plugin. [Jan] was working on his live setup recently, and didn’t want to look like a DJ playing the MacBook. Instead, he built a box that combines those powerful plugins into a single, easy to use box that sits right on top of his keyboard.
Inside this box is a modern Windows machine with a PCI Express audio interface. The display is not a touchscreen, because [Jan] originally thought a touchscreen wouldn’t be good for a live performance. He’s reconsidering that now. Other than that, you’re looking in effect at a microATX motherboard and a 10″ LCD in a box, but that’s where this build gets interesting.
The mechanical design of this build is of paramount importance, so [Jan] is using two mod wheels on the side, a bunch of silicone buttons on the bottom, and a few rotary encoders. These are MIDI controls, able to change whatever variables are available in the custom VSTs. That in itself is a pretty interesting build, with circuit bent MIDI controllers and off-the-shelf buttons.
The completed build attaches right to the Nord Stage master keyboard, and eight VST instrument channels are right at [Jan]’s fingertips. You can check out a video of this build in action below.
Continue reading “The Solution To DJs Playing Their MacBooks” →
