A cat sits on a dark green mid-century modern bench next to a cat-sized black piano. A black bowl sits beneath the piano to catch food. An abstract green, blue, and tan picture in a black frame is on the wall above the cat and a black bar stool can be seen around the corner. It looks like the sort of photo you'd see on Instagram or in an interior design magazine.
Piano Feeder Gets Pets Playing For Their Supper
If you ever watched a video of Piano Cat and wondered if your cat could learn to play, then [Sebastian Sokołowski] has a possible solution with this combination piano tutor and cat feeder.
Starting with a CNC cut MDF enclosure, [Sokołowski] developed a cat feeder that would fit in the rear of the piano. It had to be reliable, consistent, and easy to disassemble. He walks us through his testing for each of these features and says the feeder was the most difficult part of the project to develop due to the propensity of pet feeder mechanisms to jam.
A custom PCB takes the key presses from the piano (with functional black keys) and outputs the sound from a speaker in the back. Lessons progress through increasing difficulty automatically, encouraging your cat to learn what the different keys can do. Food is dispensed after a performance or on a schedule set through the accompanying smartphone app. All the files are available if you want to build your own, but there is a wait list available if you want a completed version to give to less technically-inclined cat staff.
We’re certainly no stranger to the creatures that rule the internet here at Hackaday, having featured other cat feeders, new research into spaying cats, or even open source robo-cats.
Continue reading “Piano Feeder Gets Pets Playing For Their Supper” →
An orange and white cat eats from a bowl with a hinged cover. The cat and the bowl are on top of an MDF platform.
Load Cells To Get The Right Pet The Right Food
If you have more than one pet, you may know how hard it is to tell how much each furry friend is eating. If you introduce prescription foods, then this minor annoyance can have a major impact on your pet’s health. Facing this dilemma, [tomasdiazwahl] set out to make a pet feeder that feeds his pets exactly what they need when they approach the feeder.
Using the ever-popular Arduino Uno, the feeder is connected to a platform that uses load cells to detect the pet’s weight. The weight data is then used to identify which animal is looking for food. Once the pet is identified, the correct food bowl opens. It seems this prototype only has one food chamber to keep unauthorized pets from eating the special food, but the basic idea should be extensible to two or more chambers. While some existing solutions read the pet’s microchip or NFC collars to determine who’s at the feeder, [tomasdiazwahl] decided against these given the fickleness of trying to reliably get a reader at the correct position relative to the pet. As long as you don’t have multiple pets with the same weight, it should work just fine.
This project has a nice mix of woodworking, 3D printing, and electronics showing what can be accomplished when you aren’t afraid to mix techniques. We also really appreciate that [Tomasdiazwahl] spent the extra time to include a testing procedure and safety mechanism into the project. Designing a device to improve your pet’s health shouldn’t come with a safety risk!
This isn’t the first cat feeder we’ve covered that uses weight to tell the difference between the pets, and if you want a simpler project to start with, check out this Simple Auger Pet Feeder.
