Robot Bartender Is The Life Of The Party
As the old saying goes, when the only tool you have is a 6 DOF industrial robotic arm, every problem looks like an opportunity to make it serve up adult beverages. [benkokes] found himself in this familiar predicament and did what any of us would do, but his process wasn’t without a few party fouls as well as a few head-scratchers.
One of the common problems that people who suddenly find themselves with an old industrial robot have is that there’s usually no documentation or instructions. This was true here with the added hiccup of the robot’s UI being set to Chinese. Luckily no one had changed the root password, and eventually he was able to get the robot up and working.
Getting it to make drinks was a different matter altogether. [benkokes] needed a custom tool to hold the cup as well as shake it, and 3D printed a claw-style end effector with a lid. Out of his multi-colored pack of party cups, however, the orange cups were different enough in dimension to cause problems for the shaking lid which was discovered when the robot spilled a drink all over the table.
Eventually, though, the robot was successfully serving drinks at a party. One of [benkokes]’s friends happened to be a puppet maker and was able to outfit it with a tailored tuxedo for the party as well, and he also programmed it to dance in between serving drinks, completing the AI revolution we have all been hoping for. Perhaps unsurprisingly, this is a common project for people who suddenly come to posses a large general-purpose industrial robot, while others build robots specifically for this task alone.
Continue reading “Robot Bartender Is The Life Of The Party” →
Building A Robot Bartender For Amazon
[Audax] built an unassuming side table with a party trick. It could retract a glass inside and fill it up with bourbon. The nifty device gained plenty of positive attention online, leading to a commission from Amazon to build a new version. Thus, [Audax] set about a redesign to create an even more impressive drink delivery system. (Video, embedded below.)
The story is very much one of refinement and optimization, focusing on the challenges of building a customer-facing device. With just six weeks to create the new rig, [Audax] had to figure out how to make the machine sleeker and more compact for its debut at a special event. To achieve this, he eschewed the original frame design made of aluminium extrusion, going for a 3D-printed design instead. The wire nest of the original version was then subsequently eliminated by an outsourced PCB design. Other new features included a mobile app for control and an easier way to adjust pour size, for bigger or smaller drinks as desired. For ease of use, activation is via an Amazon Alexa Skill.
As is so often the way, a last minute hurdle came up, prompting [Audax] to fly to Seattle to troubleshoot the rig on site. Nevertheless, the automatic drink server came good in the end, and delivered on its promise. Video after the break.
Continue reading “Building A Robot Bartender For Amazon” →
