The dream of fully powering everything from aircraft to cars on just the power generated from solar panels attached to the machine remains a tempting one, but always seems to require some serious engineering including putting the machine on a crash diet. The quadcopter that [Luke Maximo Bell] tried to fly off just solar power is a good case in point, as the first attempt crashed after three minutes and wrecked its solar panels. Now he’s back with a second attempt that ought to stay airborne for as long as the sun is shining.
Among the flaws with the first prototype were poor support for the very thin and fragile PV panels, requiring much better support on the carbon fiber frame of the drone. To support the very large solar array, the first drone’s arms were made to be very long, but this interfered with maneuvering, so the second version got trimmed down and the array raised above the frame. This saved 70 grams of weight from the shortened tubs, which could then be added to the new panel supports.
After an initial test flight resulted in a crash when the PV output dropped, the need for a small battery buffer was clear, so this was added, along with a reduction of the array to 4×7 panels to get the same 20V as the battery. The array also had to be reinforced, as the thin array was very wobbly in addition to making it impossible to fly with any significant wind.
Continue reading “How Long Can A Quadcopter Drone Fly On Just Solar?”
