Welded frame and cylinders for T1 #5550
Building A Steam Loco These Days Is Nothing But Hacks
The Pennsylvania Railroad (PRR)’s T1 class is famous for many reasons: being enormous, being a duplex, possibly having beaten Mallard’s speed record while no one was looking… and being in production in the 21st century. That last fact is down to the redoubtable work by the PRR T1 Steam Locomotive Trust, who continued their efforts to reproduce an example of these remarkable and lamentably unpreserved locomotives in the year 2025.
They say that 2025 was “the year of the frame” because the frame was finally put together. We might say that for the PRR Trust, this was the year of welding. Back when the Baldwin and Altoona works were turning out the originals, the frames for steam locomotives were cast, not welded. There might not be anywhere on Earth to get a 64′ long (19.5 m), 71,000 lbs steel casting made these days. Building it up with welded steel might not be perfectly accurate, but it’s the sort of hack that’s needed to keep the project moving.
The cylinders, too, would have been bored-out castings back the day. Getting the four (it’s a duplex, remember) assemblies cast as one piece didn’t prove practical, so T1 #5550 will have welded cylinders as well. Given modern welding, we expect no problem with holding steam pressure. The parts are mostly machined and will be welded-together next year.
The giant wheels of the locomotive have been cast, but need to be machined. It’s not impossible to believe that locomotive #5550 will be on its frame, on its wheels, in 2026. The boiler is already done and the injectors to get water into it have been reinvented, which can perhaps be considered another hack.
Right now, if donations continue to trickle in at the current rate– and prices don’t rise any faster than they have been– the Trust hopes to have the locomotive steaming in 2030. She’s now 59.8% complete. That’s up from 40% when we last checked in, back in 2022, which is great progress considering this is a volunteer-driven, crowd-funded effort.
If you don’t have the skills or geographical location to volunteer with this build, but we’ve piqued your love of steam, perhaps you could 3D print an engine to scratch the itch.
Continue reading “Building A Steam Loco These Days Is Nothing But Hacks”
Rusty bathtub outdoors on equally rusty car springs
Hot Rod Backyard Bath On Steel Spring Legs
In a fusion of scrapyard elegance and Aussie ingenuity, [Mark Makies] has given a piece of old steel a steamy second life with his ‘CastAway Tub’. Call it a bush mechanic’s fever dream turned functional sculpture, starring two vintage LandCruiser leaf springs, and a rust-hugged cast iron tub dug up after 20 years in hiding. And put your welding goggles on, because this one is equal parts brute force and artisan flair.
What makes this hack so bold is, first of all, the reuse of unforgiving spring steel. Leaf springs, notoriously temperamental to weld, are tamed here with oxy-LPG preheating, avoiding thermal shock like a pro. The tub sits proudly atop a custom-welded frame shaped from dismantled spring packs, with each leaf ground, clamped, torched, and welded into a steampunk sled base. The whole thing looks like it might outrun a dune buggy – and possibly bathe you while it’s at it. It’s a masterclass in metalwork with zero CAD, all intuition, and a grinder that’s seen things.
Inspired? For those with a secret love for hot water and hot steel, this build is a blueprint for turning bush junk into backyard art. Read up on the full build at Instructables.
