Thermal Grill
Your Brain Thinks Its Burning You, But It’s Not
In the cult classic Dune, there’s this fictional device called the “Pain Box”. If you touch it, you’ll feel like your hand is burning, but in reality, no tissue is being damaged. In the real world this is called the Thermal Grill Illusion, which was discovered back in 1896. Much to our chagrin, [Adam Davis] has just finished building a working prototype.
Sound familiar? We covered a similar project a few months ago — but unfortunately it didn’t work very well. Luckily, and boy do we love it when this happens, [Adam] saw the post, and got inspired to try it himself. He had actually designed a system years back but never got around to building it. Upon seeing the post — and the difficulties in making it work — he just had to figure it out.
So how does it work? The Thermal Grill Illusion uses alternating warm and cool bars which stimulate the temperature receptors in your skin — and confuse them. Neither the warm or cool bars are extreme enough in temperature to do any harm, but your confused little temperature receptors make it feel like you’re either burning or freezing your skin off!
Continue reading “Your Brain Thinks Its Burning You, But It’s Not” →
Pain Box Project
Making The Dune “Pain Box” A Reality
If you are unfamiliar with Dune, then you may not know what the pain box is. The pain box is a fictional device that produces an excruciating burning sensation without causing any actual damage. [Bryan] has been working on a project to duplicate this effect in the real world. It sounds like he may be on the right path by using the “thermal grill illusion”.
The thermal grill illusion is a sensory trick originally demonstrated back in 1896. The trick is made up of two interlaced grills. One is cool to the touch, and the other is warm. If the user touches a single grill, they won’t experience any pain because neither temperature is very extreme. However if the user places their hand over the interlaced grills simultaneously they will immediately experience a burning heat. This usually causes the person to pull their hand away immediately. It’s a fun trick and you can sometimes see examples of it at science museums.
The thermal grill illusion sounded like the perfect way to make the pain box a reality. [Bryan] has set specific constraints on this build to make it more true to the Dune series. He wants to ensure the entire package fits into a small box, just big enough to place an adult hand inside. He also wants to keep safety in mind, since it has the potential to actually cause harm if it were to overheat.
[Bryan] has so far tried two methods with varying success. The first attempt involved using several thermoelectric coolers (TECs). [Bryan] had seen PCBs etched a certain way allowing them to radiate heat. We’ve seen this before in 3D printer surfaces. He figured if they could become hot, then why couldn’t they become cold too? His idea was very simple. He etched a PCB that had just two large copper pours. Each one branched out into “fingers” making up the grill.
Each side of the grill ultimately lead to a flat surface to which a TEC was mounted. One side was cold and the other was hot. Heat sinks we attached to the open side of the TECs to help with performance. Unfortunately this design didn’t work. The temperature was not conducted down to the fingers at all. The back side of the PCB did get hot and cold directly under the TECs, but that wouldn’t work for this illusion.
The latest version of the project scraps the PCB idea and uses small diameter copper tubing for the grill. [Bryan] is working with two closed loop water systems. One is for warm water and the other is for cold. He’s using an aquarium pump to circulate the water and the TECs to actually heat or cool the water. The idea is that the water will change the temperature of the copper tubing as it flows through.
While the results so far are better than the previous revision, unfortunately this version is having problems of its own. The hot water eventually gets too hot, and it takes over an hour for it to heat up in the first place. On top of that, the cold water never quite gets cold enough. Despite these problems, [Bryan] is hopefully he can get this concept working. He has several ideas for improvements listed on his blog. Maybe some Hackaday readers can come up with some clever solutions to help this project come to fruition.
