Soundwave Tunes Up Your Portable Workbench
[Tez_Gelmir] built an awesome portable workbench. Not satisfied with just mundane designs, he patterned his box after Soundwave from the classic Transformers: Generation 1 series. This portable bench keeps his tools organized and ready to roll out.
[Tez] has all the basic tool groups covered – screwdrivers small and large, pliers, crimpers, soldering iron, fume extractor, vice, and wire spool. He’s also got room for parts boxes to hold his components.
soundwaveThe basic box is built from a single sheet of 7mm plywood. The front work area is a smaller piece of 12mm plywood. Working with 7mm plywood did prove to be a challenge – [Tez] had to use some very small screws for his hinges.  The basic box construction was easy though – [Tez] used a pneumatic nailer and PVA (wood) glue.
[Tez] used a number of 3D printed parts in his design. He kept the Transformer theme going with a Decepticon logo built into his screwdriver holder. The fume extractor and lamp were also especially clever – [Tez] mounted them to drawer sliders, so they are there when he needs them, and out of the way when he doesn’t.
[Tez] spent quite a bit of time setting up his power system, and it shows. The inside of the box is framed with four power points. The main cord has its own “mouse door”, and everything tucks neatly away when not in use.
The Soundwave paint job is what sets this box apart – [Tez] spent quite a bit of time getting everything just right. It looks like Ravage is ready to spring out at any moment.
We really love this setup – Our only suggestion would be to add some sheet metal to protect the corners of the box while in transit.
Continue reading “Soundwave Tunes Up Your Portable Workbench” →
On-the-go Tool Wallet
Whether you’re off to the local Hackerspace, or headed to a friend’s house to lend a hand with the latest project it’s nice to have your favorite tools in a handy package. [Mário Saleiro] decided to take the concept one step further than a toolbox by making his own zipper wallet with cutouts for his favorite tools.
The enclosure is a CD wallet, but who carries those plastic discs around with them anymore? After removing the CD sleeves [Mário] positioned his tools — in this case a pen, angle cutters, and pliers — on one side of the case to make a template. The tracings were then used to cut out pieces from an exercise carpet (we think this is like a rubber yoga mat). The square was glued to the side of the wallet, and some elastic band was sewn in to hold them in place. On the other side is a small components bin, and a little box to hold a tiny multimeter.
[Thanks Nuno]
