Everyone loves Wago connectors for how versatile and effective they are for quickly and securely connecting conductors, but it can be tempting to buy a bag of the significantly cheaper knock-offs. The reason why this can be a terrible idea is explained by [Big Clive] who tore down a few bags of them to ogle at their internals.
The main problem with some of these knock-offs is the way that they use the plastic molding as part of the structure that holds the conductors in place. Over time this plastic will develop larger tolerances, with heat developed from passing large currents speeding up the process. As the examined type of connector relies on metal clamps that securely push the conductor onto the busbar, having the plastic weaken, and the clamp correspondingly loosen up, is clearly not a desirable scenario.
As [Clive] says in the video, you’re probably okay using these cheapo knock-offs for a quick test on the bench, but you should never put them in a permanent installation. Not just due to potential fiery scenarios, but also for insurance claims should the worst come to pass, and the insurance company finds dodgy connectors everywhere in the electrical wiring. This isn’t the first we’ve heard of knock-off Wago problems.
Continue reading “Teardown Of Dangerous Fake Wago Connectors”
