Here’s a great hack sent in to us from [Simon]. He uses an e-paper photo frame as a weather map!
By now you are probably aware of e-paper technology, which is very low power tech for displaying images. E-paper only uses energy when it changes its display, it doesn’t draw power to maintain a picture it has already rendered. The particular e-paper used in this example is fairly large (as e-paper goes) and supports color (not just black and white) which is why it’s expensive. For about US$100 you can get a 5.7″ 7-color EPD display with 600 x 448 pixels.
Continue reading “Converting An E-Paper Photo Frame Into Weather Map”
