Make dual pin header footprints into breadboard friendly DIP
[John] wrote in with a solution to a prototyping issue that has vexed us for quite some time. Above you can see the DIP friendly solution for dual-row pin headers which he came up with. With just a bit of easy soldering he now has a breadboard friendly device for prototyping.
He starts by soldering a dual row pin header on the board, then clips off all of the legs on the outside row. The row of legs that remain are then inserted into one side of the trench on his breadboard. The other side of the trench has a single row pin header, and he solders them to the outer row on the breakout board using another single pin header aligned horizontally. This isn’t a 100% convenient solution, as it’s still pretty hard to get your jumper wires in the breadboard on the side covered by the breakout board. But if you plan in advance you can place your wires first, then plug in the development board.
Here [John] is working with TI’s eZ430-RF2500 board. We’d like to go back and remove the dual pin socket we soldered on our eZ430-F2013, replacing it with this style of pins.
Comments
  1. Jim says:
    Hah, simple, but it works. I like how he uses the breadboard itself to hold things in place while soldering – guarantees it will fit nicely when you’re done.
    • siphjiohje says:
      Not just a good fit, it also heatsinks the parts too! I do all of my header soldering that way and it saves a great deal of pain.
      • adcurtin says:
        Heatsinking while soldering is a bad idea! it helps cool down the parts, so you have to apply heat longer, which is bad.
        An easy example is thermals on a PCB: they are there so it’s possible to solder to the pad, and do so without damaging whatever component you’re soldering.
    • ftkalcevic says:
      I did that once – melted my bread board. Now I use fibreglass or phenolic proto boards as a jig.
    • reboots says:
      Unfortunately the heat re-tempers the spring contacts inside the breadboard so they can no longer maintain the tension needed for reliable operation. It’s not a good idea.
      • Brian Neeley says:
        You could always use a non-functional breadboard. No, it might not hold the board, but gravity comes in handy for that.
        As an aside, I have thought of hard-wiring a group of breadboard pins to a breakout board of some type. That way I could have a little more room on the breadboard for prototyping. I haven’t actually done it, but I also don’t do enough hacking to make it worth the effort.
  2. Smoketester says:
    Seems like you could do the same thing with angled headers so that the board would stand vertically, centered over the gutter. Then you would have better access to the row of breakouts the board covers in this configuration.
  3. plockc says:
    that’s awesome, can you do right angle header pins so you could make the board vertical (and making it easier to access the top of the breadboard) ?
  4. James says:
    Points for using what you have in your parts bin I guess, but I’d be inclined to do something tidier.
    A simple adapter pcb, with two single rows of pins on the bottom to straddle the gutter, and a double row socket on top between them.
    The actual board you are plugging in could either have just a double row straight header if it’s not so wide, or a double row right angle male header, so that it can be plugged in vertically.
  5. BJ says:
    What about mounting the thing vertically and having two rows of different height 90 degree header on each side?
  6. Gert says:
    Wait… the board completely blocks all of the holes on one side of the board, right? So he’s only using one row of the breakout pins, no? I guess he can get wires to lay flat underneath the board, but other components is a challenge.
  7. Gary says:
    I used some of Technological Arts’ boards many years ago, and they had addressed the problem nicely. For example: The
    Adapt812 Module.
  8. CupCake says:
    I like the breadboard too. It looks somewhat different than those normally found from shop. All-white, mounting holes with dual-line power plane, and smooth edges.
    Anybody know where to get the same breadboard?
  9. LordNothing says:
    what i do is get an old ide or floppy ribbon cable, cut it in half and then solder each wire to a pin on a set of male headers. you can also pot the solder connections in hot glue or epoxy if you want something that will last. of course if you dont need all the pins you can also dremel through the connector to make it smaller, tough you usually have to epoxy the cable housing so it stays together.
  10. Nate says:
    the only way I would change this is angle the first row of pins to be bent 90 degrees and then solder those exact extension pins but longer ones and then bend those the correct spacing to fit like a dip but you would then have a vertical board which is a much better way to have it with easier access to the breadboard
  11. biozz says:
    i think someone should make an adapter for this!
    ORRR extend breadbord headers inward so there touching then mark a line on them!
    breadbording is hard D8
  12. Eirinn says:
    Again, great execution, but wouldn’t it be better to somehow make a socket? I guess a standard ZIF socket could clamp down on your pins while offering breadboard compatability. When you’re done just take it out of the socket and the “extra pins” are gone :)
  13. 36 awg wire!just see this 32 awg coil in vid
  14. jj says:
    Those pins mess up the spring connectors in the breadboard something awful. Use this type instead for a long and happy breadboard life:
    https://www.sparkfun.com/products/117
  15. bsidhipong says:
    While this is undoubtedly a good hack, the neat freak in me would much rather use something like this,
    http://shop.vetcosurplus.com/catalog/product_info.php?products_id=13672
  16. albertskog says:
    Seriously? Am I the only one using a long pin header with bent legs!?
  17. cjameshuff says:
    I have done something very similar combining single-row headers and a surface-mount dual-row header to make a breadboard adaptor for dual-row female connectors.
    https://picasaweb.google.com/114008970095164847569/Electronics#5810802014242076658
  18. albertskog says:
    You are all making it to difficult! One simple dual pin header with long bent legs is all it takes!!
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 94,054 other followers
