here’s a link from maurizio that has instructions for overclocking your favorite ti graphing calculator. a simple swap of a capacitor and you can get your homework finished double speed. add a switch and you can convert back to normal speed for playing games.
this works, but I just removed the cap alltogether. No side effects except it was faster.
Of course I never even came close to using the full capacity of the calculator, but I could add and subtract at lightspeed!
Tetris was tough though.
BILL
This has been something fun to do in the TI Calc community since at least 1998.
Heads up, though- battery life will dramatically suffer if you’re overclocking (duh!). Be sure to keep a spare set if you overclock your TI and then sit for the SAT or you may find that Very Bad Things ™ will happen.
:'( Dang, there is nothing about my HP48GX!!!
here you go joel. let us know how it works out.
http://www.geocities.com/hp_upgrade/
Awesome hack. Thanks. Truly geeky.
Yep, this is truely an old hack. Getting the soldering right and getting the switch to fit were a little troublesome, but, given that I was working with a ham-fisted soldering iron and I was just barely a teenager at the time, well, it worked out quite well. It made ‘Marble’ truely interesting on the TI85.
Did this to my TI-83, worked okay for some things. Actually it wasn’t my TI, it was my high school’s. :) Anyway it worked, but I got some distortion on the screen when it was on. My HS math teacher hated me for installing games on everybody’s calculator.
will this work similarily and safely on a ti-83?
unforunately…this can make a bad calculator. I had one melt the processor when I overclocked it. It ran awesome…then died.
can it work for a ti-83+ ?
great
great
