Memristor-based Memory Prototype By 2009
An article in EETimes suggests that we may see a memristor-based memory prototype in development as soon as 2009. The memristor is claimed by many to be the theorized fourth passive circuit element, linking the fundamental circuit variables of charge and flux. This news may not sound that exciting to most computer geeks, but this new component could usher in a new era of computer memory by forming the basis of RRAM (resistive random-access memory).
Scientists at HP labs have finally confirmed that the memristor behaves as their theories predicted. The reason that the component will work so well for memory is that the process is nonvolatile and the bits themselves will only change after the CPU tells them to. The bits in current DRAM systems slowly fade out and require a refreshment every 50 nanoseconds.
[via /.]
5 thoughts on “Memristor-based Memory Prototype By 2009
  1. this is not a hack
    this is serious hi-sci-tech
    i can’t wait for had to do their first post on dna based cpus
    i can see the comments now
    “since when has bacteria been a hack? whine whine”
    great stuff keep it up
  2. besides this not being a hack (unless well, convincing molecules to exhibit memory counts as a hack, which it might), what’s with the claim of 50 _nano_second refresh period? does the author even realise how small a nanosecond is, and that a memory could not possibly require to be refreshed every 50ns, because it would spend all its time refreshing, instead of, you know, memorizing? from the wikipedia article that this post links to, a sane value would be 64ms per row, though in certain cases it could be seconds or even minutes. the snr around here is going down fast *whine whine* *bitch* *whine*.
  3. In the actual article, when they said 50ns, they meant 50ns access time, not refresh time. Since DRAM basically stores your data in a capacitor, and capacitors slow things down, it’s going to be difficult getting things faster than that without some better way of storing memory.
    I’m no semiconductor researcher, but what exactly is the difference between the today’s MRAM designs and memristors? They sure sound similar ;P
  4. Hi all, i really know how it is to suffer from a problem like this. I have been struggling from this since a few months with the normal ups and downs so i really know to have a illness like this. At some forum i found out some members were really happy about a capsule they purchased of the net and i ordered it when i found those pills at – herbalhealingstore dot com -. So you see, those herbals do work, you only have to get the good ones!
Leave a Reply to ret784Cancel reply
