Wired’s Threat Level takes us on a photo tour of the Defcon Network Operations Center, giving a unique behind-the-scenes perspective of one of the largest computer security conventions. The Defcon Network Operations Center is run by a volunteer group named the “Goons”. They keep operations running smoothly and securely with both high and low-tech resources, like a Cisco fiber switch and an armed guard, to protect the router and firewall.
Day: August 11, 2008
Wiitendo: A Wii In An NES Case
[youtube=http://www.youtube.com/watch?v=jTs8c4r8m94&hl=it&fs=1]
[Matt] has managed to cram a Wii into an old NES. The write up is fairly short, but does mention a few details. He installed some Game Cube controller ports and a Game Cube memory card. He’s added some external LEDs connected to the Wii’s power button. He put a lot of effort into this, as he said almost every area of the internal case needed some serious dremel action to make the Wii fit inside. He’s even promised a more detailed write up, so keep an eye out for that.
You might also remember the Wii Laptop previously on Hackaday.
[via Hack a Wii]
