[blakebevin]’s sister shattered the screen on his Amazon Kindle, so he decided to try replacing it with the screen from a Sony Reader. He disassembled the Sony Reader and used a Dremel to mill down most of the aluminum tabs on the E Ink screen. The screen plugs into the same harness as the original Kindle screen the only problem is fit. The new screen interferes with some of the button movement and without trimming the case will bulge a little. Performance wise the screen ghosts on page turn and [blakebevin] assumes this is due to older technology. We’d hope to never have to do this, but it’s good to know the transplant option is there and not very difficult.
Day: August 22, 2008
SyncMaster, Home Made Modular Midi Controller.
[D.St-Amand] is designing the SyncMaster, a compact modular midi controller, from scratch. The design focuses on a modular build where you can swap out pieces like the one pictured above to achieve different layouts. Not only is it modular, but its very compact. Shown next to some common competitors, it looks very sleek.
Development seems to be moving forward, the pictures have been updated frequently. Lets hope to see a fully functional demo some time soon. Some more detailed information on the build might be nice as well. This may remind you of our story on MachineCollective. While there are similarities in that they’re modular, SyncMaster appears to be a much more polished and portable product. Keep us updated [D.St-Amand].
Cutting Pizza With A Laser
In an act of delicious over kill, these guys threw a pizza into an industrial laser cutter. The result? Exactly what you would expect. Smoke, giggles and perfectly cut pizza. It looks like the cheese stuck together a bit after the laser cut, but that happens with normal pizza cutters too.
[via DVICE]
