19 thoughts on “CNC Tetris Theme
  1. @MattieShoes, I had a scanner that did that. It also came with a little command line app that worked like QBasic’s play function, so it could play other tunes too :) I wish I could remember what make and model it was :(
  2. it was a quick rendition just to wear in the machine i didnt ever imagine it would be on hackaday (my lifelong goal this week btw).
    so excuse the roughness or buy a micro and program it to do better =) and if you check you tube the mario test is on there also
Leave a Reply to neorazzCancel reply
