1-Wire LAN With An LCD
[Viktor], one of our favorite avid hackers, has been playing around with 1-wire systems all this month. What started out as a MicroLAN Fonera has turned into an iButton interface, to a 1-wire powered hub, and finally a 1-wire character driven LCD. Anyone looking at 1-wire systems or OWFS could surely benefit from his testing.
However, if you still haven’t gotten your fill of 1-wire goodness, let us remind you of the 1-wire HVAC and IPv6 to 1-wire protocol translator.
[Thanks Juan]
14 thoughts on “1-Wire LAN With An LCD
  1. Wow, this takes some serious thinking-cap to pull off. I just barely understand how he was able to pull it off. 1-Wire LAN though? I likes I likes.
  2. Holy Crap, I was just starting to think about this sort of thing. Can you use this to start up an rj11 cable network in a house?
  3. 1-wire = awesome. I use it to monitor lots of stuff on my saltwater aquarium!
    All the developers of OWFS are extremely talented/knowledgeable. I highly recommend OWFS.
  4. @The File Clerk: Not directly, 1-wire is 5V multidrop. I don’t know what the typical segment length is, but I doubt you could just throw it on the unused phone line pairs running through your house and expect it to work. Someone more familiar with large 1-wire nets want to chime in?
    On the other hand, OpenWRT-able routers can be had for ~$20, and the DS2480 is cheap too, so you could just dedicate an access point for each room you want a bus drop in.
  5. @Roon
    No, it’s more like I2C.
    1-wire devices have unique 64 bit serial numbers (think of them as MAC addresses). It’s a pretty smart (though slow) network.
  6. I love the iButton and the other but I love the lie that is “1wire”
    I dare people to run only 1 wire and make it work… no you cant ignore the ground wire.
    and yes you can just throw it on a PAIR (2 wires) of phone wires that are unused in your house and it works. I have had it working over 350 feet on cat 3 twisted pair.
  7. I’m slightly confused from fartface and No One. I’ve seen i2c called TWI (two wire interface) and i2c is just clock and signal. This one wire interface should be just that.. one wire. If it was Signal + ground, it would also be TWI, right?
  8. I²C also needs ground (for reference) and its devices generally need a power supply too (so four wires total). 1-Wire devices can potentially power themselves from the data line.
  9. @ALL
    As someone who has been using the One-Wire technology on and off for the past ten years, it is all of that and more. What he’s using is an open source project called OWFS to manage his LCD display.
Leave a Reply to Ho0d0o/HeatgapCancel reply
