Amazing RGB POV Clock
rgb_pov_propeller_clock
We’re no strangers to POV time pieces around here, but something about them never gets old. Whether they use a ring of LEDs to draw clock hands, or an intricately cut HDD platter to replicate LCD segments, we love seeing them. [David] sent in this hard drive POV clock built by a fellow named [Kly], and it’s just beautiful.
[Kly’s] “Propeller” POV clock is named as such due to the design of the circuit board. The board is mounted on the HDD spindle, rotating much like an airplane’s propeller. The construction details are sparse, but from what we can find, it is based around a PIC32MX microcontroller, which is used to control the 66 SMD RGB LEDs mounted on the circuit board.
As you can see in the video below, the tightly packed LEDs result in some pretty amazing visuals.
Aside from watching the video below, be sure to swing by his Youtube channel for a handful of videos showing RGB POV clock in action.
21 thoughts on “Amazing RGB POV Clock
Leave a Reply to tim Cancel reply
