Old Inkjet Turned Into An SVG Plotter
plotter
What do you do when you have an old printer, a portable CD player, and a handful of other electronics sitting around? Turn it into a plotter, of course.
The frame of the plotter was taken from a ye olde Epson printer, reusing the two stepper motors to move the paper along its length and width. The pen is attached to the laser head of a junked portable CD player. With this, it’s just three stepper motors that allow the Arduino control system to move the pen across the paper and put a few markings down.
The motors on the printer are, in the spirit of reuse, still connected to the printer’s driver board, with a few leads going directly from the Arduino to the parallel port interface. The motor in the CD player is another ordeal, with a single H-bridge controlling the lifting of the pen.
On the software side of things, a Processing sketch reads an SVG file and generates a list of coordinates along a path. The precision of the coordinates is set as a variable, but from the video of the plotter below, this plotter has at least as much resolution as the tip of the pen.
Continue reading “Old Inkjet Turned Into An SVG Plotter”
Foldscope Promises Microscopes For Everyone!
The folks over at PrakashLab at Standford University have come up with an amazingly simple microscope design called the Foldscope, which could make microscopes feasible in even the most remote areas.
The Foldscope is an optical microscope that can be made out of paper and printed components, much like a piece of origami. It can magnify up to 2,000X, costs less than a dollar to manufacture, and can provide a sub-micron resolution of 800nm. It requires no external power, fits in a pocket, and could survive being dropped off the top of a 3 story building!
It takes advantage of new technologies that make it possible to print micro-optics, micro-electronics, micro-flexures, and even micro-fluidics. Just take a look at the following bill of materials and diagram explaining the mechanism.
Continue reading “Foldscope Promises Microscopes For Everyone!”
Panning GoPro Mount Catches Bad Drivers On Video
gopro-mount
[Chris] must live in a neighborhood with a lot of bad drivers. He built this motorized panning GoPro mount so he can record and share his neighbors’ mobile misadventures with the world. He started with a custom machined aluminum frame. The frame clips onto a suction cup mount grab bar. The stock GoPro mount sits on a machined HDPE puck, which is rotated by a NEMA 11 stepper motor. [Chris] used a Pololu A4988 stepper motor driver to handle the coils. Initially he used an Arduino to generate pulses for the stepper driver. A true Hackaday fan though, he decided that an Arduino was overkill, and broke out a 555 timer. A DPDT switch powers up the 555 and controls the stepper driver’s direction input. The electronics all fit neatly in a small project box which doubles as a hand controller.
While setting up for a test drive [Chris] found that he could only lock down one suction cup on his car’s curved sunroof. Considering the light weight of the GoPro, one suction cup is probably enough. Just to be safe, [Chris] added a rope leash down through the sunroof.
We think the stepper motor was a good choice for this project. Since the motor is direct drive, there are no gears to strip. The stepper’s holding torque also keeps the camera pointed in the right direction at highway speeds. With no wires directly connecting the GoPro to the car, [Chris] can spin the camera 360 degrees without worrying about tangles. Verifying the camera’s direction is just a matter of looking up through the car’s sunroof. Click past the break to see [Chris’s] camera mount in action.
Continue reading “Panning GoPro Mount Catches Bad Drivers On Video”
The Ripper: A Different Kind Of CNC Machine
Here’s an awesome CNC build that crosses a standard CNC router… with a CNC machine capable of milling metal with ease. Introducing The Ripper. No, not Jack.
[Maximilan Mali] has been reading Hack a Day since he was a kid. A few years ago, he saw a guide on a DIY CNC build which inspired him to start designing The Ripper at the young age of 16. He’s 19 now (studying mechatronics in Austria), and raised enough money last summer to finally build his first prototype. It cost approximately 4000€ to build, which is pennies compared to a commercial machine of this caliber.
The machine has a bed size of just over a meter squared, with a Z height of 225mm. It’s also rigid enough to slice through aluminum at 850mm/s with ease! Take a look at the following video — we’re very impressed. Our favorite part is when he shows off its accuracy and repeatability by plunging a tool towards the screen of his very own iPhone.
Continue reading “The Ripper: A Different Kind Of CNC Machine”
Billboard Advertises Engineering School, Manufactures Potable Water
It’s a remarkable thing when ad agencies manage to help people in the course of advertising. The University of Technology and Engineering Peru (UTEC) was looking for ways to increase enrollment. They went to the Peruvian offices of agency DraftFCB and came away with the idea to install a billboard that converts Lima’s water-saturated coastal desert air into potable water.
Perhaps the only downside is that it requires electricity, and not just for those cool neon water drops. There are five generators that capture the humidity and use reverse osmosis to purify the water. Each of these units has a tank that holds 20L. From there, the clean water is aggregated in a main tank and can be collected from a faucet at the base of the billboard. In just three months, the billboard produced over 9,000L (2500 gallons) of potable water for people who would otherwise draw polluted water from wells.
We love to see hacks that help. Use your powers for good, like re-purposing humid air and pollution. Make the jump to see a short video and an artist’s conception of the billboard’s innards.
Continue reading “Billboard Advertises Engineering School, Manufactures Potable Water”
Hackaday 68k: Gluing Architecture Buffer Maps
68000It’s time for more blatant advertising for Hackaday Projects, the best project hosting site on the Internet. Did we tell you it’s collaborative? That you and your friends can work on projects together? Want more encouragement to join? How about a contest with prizes that include oscilloscopes, FPGA dev boards, soldering and rework stations, Beaglebones and Raspberries and Spark Cores? Oh my!
Oh. We’re also developing a retrocomputer to show off the features of Hackaday Projects. This is the latest update, showing off the architecture of the entire system, the memory map, and the logic glue and buffers. The plan for this project is to have it host another awesome Hackaday site, our retro version, a small off-shoot of the main Hackaday site that’s specifically designed to be loaded by computers built before 1993. There haven’t been many retro successes in the Hackaday tip line recently, so if you manage to get a vintage computer to pull the retro site up, snap a pic and send it in.
For those of you wanting to catch up on the Hackaday 68k project, here’s the Hackaday Projects page, and here’s all the front page updates. Click that ‘Read more…’ link for the update.
Continue reading “Hackaday 68k: Gluing Architecture Buffer Maps”
Cleaning Up Smoke With An Electrostatic Precipitator
[Steve Dufresne’s] got another great project for us — a device that effectively gets rid of smoke!
It’s called an electrostatic precipitator and it works similar to the way many cars are painted today using a process called electrostatic coating. Electrostatic coating works by giving the paint particles an electrostatic charge, opposite to the charge on the vehicle’s body panels — this makes the two attract and results in using around 95% of sprayed paint — barely any over-spray, and a better bond to boot!
[Steve’s] tried this experiment of creating a smoke precipitator with the eventual goal of using it on a car’s exhaust. He’s been through a few designs so far, and finally has one that works quite well. It’s not even that complicated, just take a look at the following diagram.
Continue reading “Cleaning Up Smoke With An Electrostatic Precipitator”
