Quadcopter Beer Delivery System
One of the major design challenges when it comes to building an efficient quadcopter is weight. The idea here is that the more you can trim down the weight of the frame, motors, and circuitry, the longer the batteries will last. Or, in [dalbyman]’s case, the more beer it can carry.
[Dalbyman]’s housemate built the actual quadcopter, but then [dalbyman] got a little inebriated and decided that, while the quadcopter was exciting on its own, it would be even better with this modification. The actual device is a modified Pringles can with two servo motors on the bottom with arms that hold the beer. A parachute is attached to the beverage can and the assembly is loaded in. With a simple press of a button, the servos turn the arms and the beer falls out of the tube. Hopefully the parachute deploys and gently (and accurately) floats the beer to the thirsty person on the ground!
This project is a simple step that goes a long way towards a beer delivery system even Amazon could be proud of, and also shows off the capabilities of quadcopters in general. Perhaps the next step could be to automate the beer delivery system!
7 thoughts on “Quadcopter Beer Delivery System
  1. This concept was commercially implemented last year at a local 3-day music event in South Africa. You would order with your smart-phone, cost would be deducted from your credit card, then a drone would home in on your smart-phone’s GPS location and drop a frosty with a parachute.
    Pretty high-tech for a ruddy 3rd-world country if you ask me!
Leave a Reply to PaulCancel reply
