Dumping U8Plus Smartwatch ROM Via Vibration Motor
[Lee] continues with his exploration of the U8Plus (a cheap smartwatch). He hasn’t got it all cracked, yet, but he did manage to get a dump of the device’s ROM using an unusual method. At first, [Lee] thought that the JTAG interface (or, at least, the pins presumed to be the JTAG interface) would be a good way to explore the device. However, none of the people experimenting with the device have managed to get it to work.
Instead, [Lee] went through the serial bootloader and dumped the flash memory. He found out, though, that the bootloader refused to read the ROM area. It would, however, load and run a program. Unfortunately, no one has found how to access the UART device directly, but they have found how to drive the vibration motor.
[Lee] took off the vibration motor and used it as an output port for a simple program to dump the ROM. An Arduino picked up the data at a low baud rate and produced an output file. This should allow more understanding of how to drive the watch hardware.
We covered the initial teardown of this watch earlier this year. Of course, if you don’t want to reverse engineer a smartwatch, you could always build your own.
24 thoughts on “Dumping U8Plus Smartwatch ROM Via Vibration Motor
    1. Sorry, I should of taken a short video of it running though the first few bytes, before I removed the motor – that’s just what it was like :)
    1. Just display it as one pixel representing one bit (black/white), then use the Pebble developer tools’ screenshot feature. No OCR needed, just read the value of every pixel!
  1. China culture needs to change to a “share freely” culture. these devices would utterly destroy the big guys markets if the source code and API details for the hardware were released freely.
    They want to sell devices, selling millions more because some hackers out there wrote a better firmware is a huge advantage.
    1. I don’t see your point. The hacker market is small. Someone writing better firmware only improves the product if the manufacturer includes it in their product, or if the buyer is willing to load that firmware into the hardware they just bought. All the Chinese need to do is sell something of equal or better functionality (even if lower quality) at a lower price for the mass market.
    2. Documentation and hosting costs money. Their goal is to be as cheap as possible.
      Awesome idea though. I just don’t think it’s economically feasible for them (yet).
  2. I do not think that “[Lee] took off the vibration motor and used it as an output port”, ‘it’ presumably referring to the motor itself. Is this why HaD is looking to hire new writers?
Leave a Reply to LeeCancel reply
