Someone left this organ out in the rain, but [Tinkartank] rescued it and has given it a new life as a SID controller. What’s a SID, you ask? That’s the sound chip Commodore used in the C64, a remarkable chip revered among retro gamers that was way ahead of its time.
He threw out everything but the keyboard assembly for the build. Each key press now drives a momentary button, and those are all wired up to an Arduino Mega through some I/O expansion boards left over from another project. The Mega drives the MOS6581 SID chip which generates those sweet chiptunes. There are four CV outs for expanding the organ’s horizons with Eurorack modules.
Our favorite part is the re-use of the stop knobs — particularly that they are actuated the same way as before. The knobs still technically control the sound, but in a new way — now they turn pots that change the arpeggio, frequency, or whatever he wants ’em to do.
The plans for the future revolve around switching to a Teensy to help out with memory issues. Although it’s a work in progress, this organ already has a ton of features. Be sure to check them out after the break.
Once you dive down the chiptunes rabbit hole, you might want to take them everywhere. When you get to that point, here’s a portable SID player. A SIDman, if you will.
I like how he converted the linear motion of the stops into rotary motion for the pots!
“Someone left an organ out in the rain…” apologies to Jimmy Webb
Yes, Kinda makes you wonder why he didn’t use slide pots to avoid that issue all together.
They take an absurd amount of PCB space?
Slide pots would introduce another mechanical constraint that may cause the assembly to bind.
It was actually the easiest way to do it. The rods were working like that originally, so I just replaced the old metal bars with potentiometers.
Universe Alpha: “It’s a shame such a cool old instrument was torn up to make this.”
Universe Beta: “It’s such a shame that this organ is broken”
Universe Gamma: “It’s such a shame to use these old organ reeds as a synth for my Commadore.”
If it was possible to fix, I would fix it. I love old technology of all kind :-) It was REALLY damaged when I found it.
Sounds like something Kraftwerk would have used. Bravo!
I guess you have also seen the really similar Chipophone build by lft some 7 years ago. It is built using a modified electric organ, rather than a mechanical one as also features a MOS6581 SID for the sound synthesis. https://www.youtube.com/watch?v=m1pchpDD5EU
Yes, someone showed it to me after I startet the building the SID Organ. A good hack! However, I don’t think he use a MOS6581, but his own atMega soft-synth. Which is even more impressive…
Pulling out all the stops… I see what you did there!
I’ll accept your musical pun. >_>
I’ve got a box of Commodores and a dual manual electric organ keyboard, with all it’s original stops… Hmm…
If it got rained on, the keys are in good shape. To bad this is not an American reed organ, you would have had a whole row of stops to play with. This was for effect! More knobs to do the same 2 ranks of reeds just like this 4 knob organ. Instead of 10 or more, PT Barnum style.
Sliders are open to dust and grit. Many pro boards used cable and pulley rotary slides for rotary pots to have a sealed reliable no noise action. Even Hammond did rack and pinion pots for pedal in some of their drawbar models.
When I found it, the keys were all swollen and the whole keyboard was warped like a sine wave. I had to dry it indoors for a few weeks, and glue the ivory back on on some of the keys..
You will probably enjoy The Chipophone if you liked this. https://www.youtube.com/watch?v=m1pchpDD5EU
