Acrylic Stencils Help With Component Placement For SMD Assembly
Surface mount is where the action is in the world of DIY PCBs, and deservedly so. SMDs are so much smaller than through-hole components, and fewer holes to drill make surface-mount PCBs easier to manufacture. Reflow soldering is even a snap now thanks to DIY ovens and solder stencils you can get when you order your boards.
So what’s the point of adding another stencil to the surface-mount process? These component placement stencils are [James Bowman]’s solution for speeding up assembly of boards in production runs too small to justify a pick and place robot. [James] finds that placing small components like discrete resistors and caps easy, but struggles with the placement of the larger components, like QFN packaged microcontrollers. Getting such packages lined up exactly is hard when the leads are underneath, and he found repositioning led to smeared solder paste. His acrylic stencils, which are laser-cut from SVGs derived directly from the Eagle files with a script he provides, sandwich the prepped board and let him just drop the big packages into their holes. The acrylic pops off after placement, leaving the components stuck to the solder paste and ready for their trip to the Easy Bake.
[James] claims it really speeds up hand placement in his biggish runs, and it’s a whole lot cheaper than a dedicated robot. But as slick as we think this idea is, a DIY pick and place is still really sweet.
12 thoughts on “Acrylic Stencils Help With Component Placement For SMD Assembly
    1. We get a lot of tip submissions. Some people submit tips to multiple outlets. Of course, we also read many of the same external blogs that you do. And they read us!
      (Phil Torrone, now at Adafruit, started Hackaday and still feeds us tips nearly fifteen years later. How cool is that?)
      But when we read about something somewhere else, we’ll put a via link at the bottom to show some respect / kick some love to the original site. And when tipsters write in with something, we thank them.
      If none of the above, you can assume that the OP submitted the tip or that we stumbled on it ourselves.
      (Or that we forgot to thank the tipster. It’s happened. Sorry! But it’s the exception rather than the rule.)
      TL;DR: Coincidence. We attribute.
      1. just getting to see this now. if it’s helpful for the reader (or the author) hackaday rarely, if ever, posts anything i send in. and if there are posts that are on both adafruit and hackaday, it’s a coincidence. i started hackaday and post over on adafruit (and before that make) the topics are usually electronics and hacky stuff, there will be some of the same things covered once and awhile. that being said, hackaday does not cover adafruit stuff much, so adafruit’s site would be the best place for that.
Leave a Reply to Phillip TorroneCancel reply
