ABS: Three Plastics In One
It would be really hard to go through a typical day in the developed world without running across something made from ABS plastic. It’s literally all over the place, from toothbrush handles to refrigerator interiors to car dashboards to computer keyboards. Many houses are plumbed with pipes extruded from ABS, and it lives in rolls next to millions of 3D-printers, loved and hated by those who use and misuse it. And in the form of LEGO bricks, it lurks on carpets in the dark rooms of children around the world, ready to puncture the bare feet of their parents.
ABS is so ubiquitous that it makes sense to take a look at this material in terms of its chemistry and its properties. As we’ll see, ABS isn’t just a single plastic, but a mixture that takes the best properties of its components to create one of the most versatile plastics in the world.
Continue reading “ABS: Three Plastics In One”
True Transparent Parts From A Desktop 3D Printer
We’re no strangers to seeing translucent 3D printed parts: if you print in a clear filament with thin enough walls you can sorta see through the resulting parts. It’s not perfect, but if you’re trying to make a lamp shade or decorative object, it’s good enough. You certainly couldn’t print anything practical like viewing windows or lenses, leaving “clear” 3D printing as more of a novelty than a practical process.
But after months of refining his process, [Tomer Glick] has finally put together his guide for creating transparent prints on a standard desktop FDM machine. It doesn’t even require any special filament, he says it will work on PLA, ABS, or PETG, though for the purposes of this demonstration he’s using the new Prusament ABS. The process requires some specific print settings and some post processing, but the results he’s achieved are well worth jumping though a few hoops.
According to [Tomer] the secret is in the print settings. Essentially, you want the printer to push the layers together far closer than normal, in combination with using a high hotend temperature and 100% infill. The end result (hopefully) is the plastic being laid down by the printer is completely fused with the preceding one, making a print that is more of a literal solid object than we’re used to seeing with FDM printing. In fact, you could argue these settings generate internal structures that are nearly the polar opposite of what you’d see on a normal print.
The downside with these unusual print settings is that the outside of the print is exceptionally rough and ugly (as you might expect when forcing as much plastic together as possible). To expose the clear internals, you’ll need to knock the outsides down with some fairly intense sanding. [Tomer] says he starts with 600 and works his way up to 4000, and even mentions that when you get up to the real high grits you might as well use a piece of cardboard to sand the print because that’s about how rough the sandpaper would be anyway.
[Tomer] goes on to demonstrate a printed laser lens, and even shows how you can recreate the effect of laser-engraved acrylic by intentionally putting voids inside the print in whatever shape you like. It’s a really awesome effect and honestly something we would never have believed came off a standard desktop 3D printer.
In the past we’ve seen specialized filament deliver some fairly translucent parts, but those results still weren’t as good as what [Tomer] is getting with standard filament. We’re very interested in seeing more of this process, and are excited to see what kind of applications hackers can come up with.
Continue reading “True Transparent Parts From A Desktop 3D Printer”
Biology Lab On Your Christmas List
We hope you have been good this year because we have a list to start your own biology lab and not everything will fit into Santa’s bag (of holding). If you need some last minute goodie points, Santa loves open-source and people who share on our tip line. Our friends at [The Thought Emporium] have compiled a list of the necessary equipment for a biology lab. Chemistry labs-in-a-box have been the inspiration for many young chemists, but there are remarkable differences between a chemistry lab and a biology lab which are explained in the Youtube video linked above and embedded after the break.
If you are preparing to start a laboratory or wondering what to add to your fledging lab, this video is perfect. It comes from the perspective of a hacker not afraid to make tools like his heat block and incubator which should absolutely be built rather than purchased but certain things, like a centrifuge, should be purchased when the lab is mature. In the middle we have the autoclave where a used pressure cooker may do the trick or you may need a full-blown commercial model with lots of space and a high-pressure range.
Maybe this will take some of the mystique out of starting your own lab and help you understand what is happening with a gel dock or why a spectrophotometer is the bee’s knees. There are a handful of other tools not mentioned here so if this is resonating, it will be worth a watch.
Continue reading “Biology Lab On Your Christmas List”
