If you only need to travel at around 25 mph around town or to get a short distance to work, an electric bicycle might just be the best thing you can ride. It’s cheap, quick, and fun, and sometimes a great way to get some exercise too. If you want to dial up the amount of excitement, though, you’re going to want something with a little more power and speed. Something like an old dirt bike converted to a 6 kW electric motorcycle.
This is the latest build from [Boom Electric Cycles] and uses the frame from an early-90s Suzuki dirt bike as the foundation. From there it’s all new, though, as the engine was removed and replaced with 3 kW hub motors in each of the wheels. A 72-volt custom battery with 240 18650 cells pushed the amps through the motors, making this bike able to keep up anywhere except the fastest highways (if it’s street legal at all…).
Having about eight times more power than is found in a typical electric bicycle is sure to be a blast, but this build isn’t quite finished yet. Some of the trim panels need to be finished and the suspension needs to be adjusted, but it looks like it’ll be out and about any day now. Until then you’ll have to be satisfied with other projects that managed to cram in 3 kW per wheel.
