Have you built a 3D scanner yet? There’s more than one way to model those curves and planes, but the easiest may be photogrammetry — that’s the one where you take a bunch of pictures and stitch them into a 3D model. If you build a scanner like [Brian Brocken]’s that does almost everything automatically, you might consider starting a scan-and-print side hustle.
This little machine spins objects 360° and triggers a Bluetooth remote tethered to an iPhone. In automatic mode, it capture anywhere from 2-200 pictures. There’s a mode for cinematic shots that shoots video of the object slowly spinning around, which makes anything look at least 35% more awesome. A third mode offers manual control of the turntable’s position and speed.
An Arduino UNO controls a stepper that moves the turntable via 3D printed-in-place bearing assembly. This project is a (vast) improvement over [Brian]’s hand-cranked version that we looked at over the summer, though both are works of art in their own right.
Our favorite part aside from the bearing is the picture-taking process itself. [Brian] couldn’t get the iPhone to play nice with HC-05 or -06 modules, so he’s got the horn of 9g servo tapping the shutter button on a Bluetooth remote. This beautiful beast is wide open, so fire up that printer. You can watch the design and build process of the turntable after the break.
Want to scan some really tiny things? Make a motorized microscope from movie machines.
I was looking to build one ages ago but my procrastination has finally brought me here. Sometimes good things come to people who wait however I should not be rewarded for my laziness. All I want to say is thank you, thank you, thank you, thank you, oh yah one more thing …thank you… Now what color am I going to 3D print mine hmmmm…………….
Now point us to some easy-to-use, inexpensive, readily available, pre-compiled, well documented photogrammetry software.
Meshroom might be what you are looking for.
https://alicevision.org/
I’ve found MeshRoom – https://github.com/alicevision/meshroom worked first time for me.
3DF Zephyr. They have free version that allows up to 50 pictures.
