Hackaday editors Elliot Williams and Mike Szczys check in on the best hacks from the past week. All the buzz is the algorithm that can reverse engineer your house keys from the way they sound going into the lock. Cardboard construction goes extreme with an RC car build that’s beyond wizard-level. Speaking of junk builds, there’s a CNC mill tipped on its side grinding out results worlds better than you expect from something made with salvaged CD-ROM drives. And a starburst character display is a clever combination of laser cutting and alternative using UV-cured resin as a diffuser.
Take a look at the links below if you want to follow along, and as always, tell us what you think about this episode in the comments!
Direct download (60 MB or so.)
Episode 082 Show Notes:
New This Week:
Interesting Hacks of the Week:
- Mini CNC Mill Goes Horizontal To Reuse CD Drives
- Four Years Later, Off-Grid Office Shed Still Rocks
- Stealing Keys From The Sound Of The Lock
- Prop-Driven Cardboard RC Car Doesn’t Skimp On Performance
- Breaking Smartphone NFC Firmware: The Gory Details
- Unique LED Display Inspired By Fighter Jet Dashboard
Quick Hacks:
- Elliot’s Picks:
- Mike’s Picks:
Hi, why there is no hackaday podcast in Google podcast app? It looks like someone delete channel and all files…
This podcast has suddenly disappeared from Google Podcasts. The icon changed and if I search for it I only find other podcasts with the word hack in them.
