Smallest Discrete Transistor 555 Timer
Over at Tiny Transistor labs, [Robo] took it upon himself to reproduce the classic 555 timer in discrete transistor form. For bonus points, he also managed to put it in a package that’s the same basic size, pin compatible with, and a plug-in replacement for the original. The first task was deciding which 555 circuit to implement. He examined a handful of different implementations — and by examined, we mean dissected them and studied the die circuitry under a microscope. In the end, he went with Hans Camenzind’s original circuit, both as a tribute and because it used the fewest transistors — a point which helped manage the final size, which is only a little bit bigger than the IC!
Speaking of sizes, have you ever soldered an EIA 01005 resistor? We agree with [mbedded.ninja] who wrote on a post about standard chip resistor sizes, the 01005 is a “ridiculously small chip package that can barely be seen by the naked eye.”  It is 16 thou x 8 thou (0.4 mm x 0.2 mm) in size, and despite its name and placement in the Imperial series, it is not half the size of an 0201. The transistors are your standard 2N3904 / 2N3906, but purchased in a not-so-standard DFN (Dual Flat Pack, No Leads). We might think a 1.0 x 0.6 mm component as small, but compared to its neighboring resistors in this circuit, it’s huge.
[Robo] has done this kind of project before, most recently making a discrete recreation of of the classic 741 op-amp. We covered a similar, but larger, discrete 555 timer project back in 2011. If you want to go really big-scale with your own reproduction project, check out the MOnSter 6502 from five years ago for further inspiration. Thanks to [Lucas] for the tip.
28 thoughts on “Smallest Discrete Transistor 555 Timer
  1. 01005 is close to the size of a grain of table salt. No way I can hand solder those! The smallest I can do is 0603 and I prefer to use 0805 for hand soldering.
    1. Some 10-15 years ago it was common to hear this about 0805 SMD parts. “No way I can hand solder those! The smallest I can do is TO-3 package.”
      1. There’s confidence, but there’s also equipment and surface tension. Due to surface tension with an iron, 0603 is realistically as small as many people can do. Most hot air stations blow smaller parts off the board. When a reflow oven is doing the soldering, it doesn’t matter the size once the parts are placed.
        1. That’s exactly my point. Nobody’s eyesight has become better since 10 years ago, but people learn to use the right tools.
        2. People who have problem with hot air often just set it too high, with hot air I can go down to 0402 easily with the naked eye (I am very short sighted, that helps).
          Using magnification makes anything smaller possible with tweezers and patience, but not that hard, the smaller it is, the less heat you need, so the less airflow you need.
          Using an oven for small parts without pick and place is infuriating, the smaller they get, the higher chance they have of tombstoning…
          In general, soldering fine things is as much a matter of experience as it is a matter of having good tools (Mainly a quality hot air station, fine leaded solder, and fine tweezers)
          1. Yeah ive done a fair bit of 0402 lately… Both leds and resistors.
            Also done both with hot air and sometimes iron… though iron is tricky.
  2. Awesome work – if Robo could move the pins inward so that the discrete 555 could plug in into an
    existing 555 board, that would be fantastic
  3. Could this be the perfect place for “could have just used a 555”?
    Whilst I’m all for doing something for the sake of it, there’s something odd about making the smallest version of a large version of small thing made out of large things.
      1. Having lookes at RS and Farnell I’m surprised the smallest 555 you can get is as large as 5mmx4mm. Hasn’t anyone done a minuscule BGA version?
          1. Can mainly be used in areas where one needs something to be small.
            But where one doesn’t need much else, and volumes are fairly low.
            It is more or less a specialty chip at that point.
  4. I appreciate the effort this takes, but you have to be a masochist to try to pull it off. Just thinking about hand soldering it gives me a headache. He could put together a whole guide on soldering techniques for these microscopic parts. I see he uses a hand soldering iron and no reflow.
  5. [Could have done this with a 555 -> not]
    Many say to use a 555 as WDT because the internal micro-controller WDTs are not considered fail-safe as software is blah blah. I have used a 555 solution where power consumption is not a design issue and where cannot be dependent on the controller’s internal timer; but use of specialty ICs as an external reset source is indicated and probably less design effort and more reliable.
    And ‘low-current’ 555 solutions using external power-steering transistors is not a good fail-safe solution because you are banging input power on and off which can never be considered to be reliably mono-tonic and you are reducing reliability by adding even more components.
  6. Wow. Meanwhile, some of us old folks distinctly remember complaining about trying to pick up 1/8th watt resistors & having to resort to forceps…LOL
  7. He could have made it smaller. That PCB substrate is pretty darned thick. If I were doing this, I would have routed out some channels to install parts inside the board for a more 3D (as opposed to his single-sided) approach. Get it smaller than a SOIC.
Leave a Reply to Mr. AnnoyingCancel reply
