3D Printed Strain Wave Gearbox
3D-printed gearboxes are always an interesting design challenge, especially if you want to make them compact. [ZeroBacklash] created a little strain wave gearbox (harmonic drive) for when you want to trade speed for torque on NEMA 17 stepper motors.
Strain wave gears work by deforming a stationary flexible spline into an ellipse so the teeth engage the internal teeth of the output spline. Add a couple of extra teeth on the output side, and you get a high-reduction gearbox with fewer parts and reduced volume than equivalent spur gearing. Keeping the flexible spline stationery is achieved by making half of it engage with a stationary spline with the same number of teeth.
In this case, there are 60 teeth on the input side and 62 on the output, giving a gear ratio of 30:1. The flexible spline is deformed using a set of bearing balls and an elliptical plug on the shaft of the motor. It makes for a compact design that matches the frontal size of the stepper motor and is only about 27 mm long. [ZeroBacklash] has not released any design files, but the idea should be simple to replicate.
We’ve featured a couple of 3D printed harmonic drives of different sizes, but they usually use a pair of ball bearings as the wave generators, which doesn’t lend itself well to smaller designs.
19 thoughts on “3D Printed Strain Wave Gearbox
    1. Right? I’m not a big fan of this synthesized voice trend taking over the internet. It makes things less approachable as a viewer
      1. Maybe some people are not confident in their speaking voice due to natural impediments, thick accent, or their English not being fluent.
          1. Time to petition Youtube to allow selecting between audio tracks, so you could have one without the speech. The subtitles are already there.
      2. The problem isn’t in the synthesized speech, the problem is in the text itself. If the voice was used to speak normal (or better chosen) sentences (in combination with some decent punctuation) things would sound way better.
        The opening does not sound natural at all and the hello sounds very awkward, getting off on the wrong foot and going down hill from there. But videos with synthesized speech do not have to be bad at all.
Leave a Reply to bootstrapCancel reply
