A Pico-Based ZX Spectrum Emulator
The ZX Spectrum was a popular computer of the 8-bit era. Now, it’s possible to emulate this machine on a microcontroller so cheap that it’s literally been given away on the front cover of magazines. Yes, we’re talking about the Pico ZX Spectrum project.
The project consists of all the necessary code to emulate a ZX Spectrum upon the hardware of the RP2040 microcontroller that makes up the Raspberry Pi Pico. The community has then taken this code and run with it, using it as the basis for all manner of different ZX Spectrum builds. If so desired, you can go barebones and use the Pico to run a ZX Spectrum off a breadboard with HDMI video output. Alternatively, you can build something like the PicoZX from [Bobricius]. The handheld computer features a PCB-based housing, along with an LCD and an integrated keyboard. Other configurations support features like USB keyboards, VGA outputs, and working sound output.
It’s great to see a classic 8-bit computer reimagined in all kinds of new tribute form factors. The Spectrum was always beloved for its neat all-in-one design, and there are several modern remixes that riff on that theme. The fact that they can all be powered by a cheap single-board microcontroller is all the more astounding. Video after the break.
23 thoughts on “A Pico-Based ZX Spectrum Emulator
  1. The project from the picture looks like it achieved something I tought was absolutely impossible:
    Building a computer with a worse keyboard than the original Spectrum.
    A ZX Spectrum was my first computer. I loved my speccy. I still have it. I typed in endless programms on that gummy atrocity of a keyboard it came with and I still feel the pain today.
          1. Yes and No. It was not cost cutting, it was Commodore using what it had on hand to release the PET as quickly as possible, and remember, in 1977 there was no standard for keyboard layouts in the birthing personal computer landscape.
            Having said that, it was STILL way way way better than the godawful Spectrum dead flesh abortion of an input device.
      1. ZX80/81 agreed. But even the crappy and odd calculator layout of the original PET 2001 was WAY better than the dead flesh Spectrum 16/48kb keyboard. WAY better.
    1. If you want a DIY keyboard, especially for small and low profile, the switches used here are the most common. Unfortunately, they are also crap. The small top is great for poking out of a (labelled) backplate, but lousy for actual typing.
      If manufacturers have a switch with the same PCB area, but a larger area button on top, it’s not easy to find. There are several projects besides this one, that would benefit from such a switch.
      1. It may not work for this specific board, where the switches need a long button to poke up through a layer of PCB, but it’s quite reasonable to 3D print wider keycaps for these little switches. With a well-calibrated printer you should be able to make them a press-fit with no post-print rework required.
    1. A banana is an improvement over the original Spectrum keyboard. I can still hear C64 owners howling laughter after seeing the cheapie competitor from Sir Clive. :)
    1. I think the same, but in a more sarcastic way. Graphics like ZX Spectrum and CGA deserve a monochrome screen. Both would looks most eyefriendly on a 1950s-1970s b/w TV set over RF cable. I really mean it.
      PS: I think the handheld was well done, all in all. I’m just not a ZX Spectrum fan due to the way graphics work,I guess. I’d rather use a ZX81 instead. The game collection of the ZX is very depressing, very British I think. Not my taste. On the bright side, the ZX Spectrum has a few nice amateur radio programs for RTTY and SSTV. So that would be an interesting aspect to tinker with.
      1. ‘The game collection of the ZX is very depressing, very British I think’
        I really don’t understand…one of the universally acclaimed strengths of the ZX Spectrum was the huge amount of game software it had from all manner of developers
        I mean people are still writing games for the Spectrum now, 40 years after its release
      2. Erm, you are quite wrong here. The Spectrum uses 15 colours – essentially 8 colours with two different luminance settings (black at half luminance is still black – so two blacks). It is a digital set palette. So, in other words, since so many of the colours had the same luminance setting, if displayed on a monochrome monitor then many colours would be the same identical shade of gray. For instance, blue, green and red would all display as 50% gray, and bright blue, bright green and bright red would all display as 80% gray (roughly). So if you had a game, for instance, that had blue characters moving over a green background, you would not see any of it.
        For systems like the Spectrum you NEED a colour display for it to be usable and not look terrible.
  2. It always surprises me the amount of negative comments aimed at Sinclair computers by people who never used them. I had a 16k, grey keyed Spectrum from new and enjoyed every single moment learning to program it. The keys had a good click, or beep depending on the value you used on “Poke 23609,xxx”. The shortcut commands quickly became instinctive and switching to a BBC was slow and tiresome to program in comparison. There were many shortcomings which are easy to criticise now, but there were many revolutionary things which inspired owners into a career in IT. If it was as bad as people would have you believe, why would people still talk about them now, and recreate modern versions.
    1. I only have one point of critique for that system, no real support for mass media, everything is build around the tape. A port of Maniac Mansion for example would be a true test of patience, not speaking of Ultima. I tried Gauntlet 2 and the constant loading from tape ruined an otherwise passable port.
      My father had one back when they where still fairly new, sold it a fortnight later and got himself a C64 with a 1541 and SpeedDOS. Not because of the hardwares capabilities but because of load times and, thanks to the medium of choice, very few RPGs. All the heavy hitters needed multiple disks on the C64 and would have been nigh impossible on the Spectrum.
    2. :) I had a Speccy back in the day, and now have dozens of them. They WERE crap, especially compared to their competitors – C64, Atari 8 bit etc. HOWEVER, they were cheap and well supported by software developers, and the hardware was pushed to its very limits in many ingenious ways. THIS is what makes the Speccy such an interesting machine in modern times – the fact that it is so very primitive – even back in its day, and yet, some truly innovative solutions around its caveman hardware were, and still are, found to host software that really has no business even being attempted on the ole’ doorstop colour clash generator.
Leave a Reply to bastetfccf6ee037Cancel reply
