Recreating The Pop Ball
Those who were kids in the 80s may remember a sweet little toy called the Pop Ball. A simple rubber hemisphere, this rubber cup could be turned inside out and thrown on the ground, where it would hit and bounce sky high whilst knocking itself right side out. The black ones worked particularly well, and were the first to be banned from [electrosync]’s school along with yo-yos, slap bracelets, and any number of toys that eventually became weaponized by enterprising children.
An industrial Vegemite injection-molded version that only kind of worked.
You can still find Pop Balls today, but they don’t work nearly as well as they did originally because of a lower Shore hardness in the rubber. Naturally, as an adult with futuristic toys at hand, [electrosync] just had to try re-creating the ’80s version. But it wasn’t easy.
They started by studying the patents and anything else they could find. They even managed to get a hold of Peter Fish, the original creator of the Pop Ball, to get some questions answered about the things. According to Peter, the black Pop Ball was made from recycled rubber and worked almost too well. Peter sent [electrosync] an old-stock Pop Ball, which they used to modify their CAD design.
It’s easy to root for [electrosync] throughout this journey, which consists of many failed prints and injection molding attempts. At last, they are able to at least recreate the snap of the modern Pop Ball once they finally found the right filament — the extremely elastic Recreus Filaflex 60A TPU. Of course, it wasn’t all lollipops and rainbows from there, because the filament is notoriously difficult to print with, but [electrosync] made it work. Check it out after the break.
Thanks to [Zane Atkins] for the tip!
14 thoughts on “Recreating The Pop Ball
    1. Make your own:
      Cut a section of tape measure longer than the bracelet you want
      Drive a nail partway into a piece of wood, with more than the width of the tape measure exposed. Make sure the wood is stationary (exposed stud, something you can stand on, etc.)
      Hold one end of the tape measure section in each hand, convex (unmarked) side facing you. Bend the tape measure over the nail, writing outward, and pull back and forth like a rope saw, with good tension on the nail.
      Cut off the parts of the ends that didn’t get rolled over the nail, round the corners. Cover with a thick fabric sleeve.
  1. Back in the 70’s Edmund Scientific used to sell these bi-metallic disks that jumped really high.
    Ah, so many great toys banned since then.
  2. We take my kids to a kids play place that has these as little knick knacks for a long with other cheap toys (I think they sell them for a dollar a piece). I got one because why not and that thing has some serious kick. It easily hits our 10′ ceilings and will do 20′ in the open air. And boy does it sting like crazy if you let it launch from the palm of your hand or if you try to grab it just after takeoff.
    I don’t know if it’s just one manufacturer not caring about “safety” improvements or if this is what all the nerfed ones do, but the ones at this play place aren’t messing around.
Leave a Reply to tonyvrCancel reply
