Humans Can Learn Echolocation Too
Most of us associate echolocation with bats. These amazing creatures are able to chirp at frequencies beyond the limit of our hearing, and they use the reflected sound to map the world around them. It’s the perfect technology for navigating pitch-dark cave systems, so it’s understandable why evolution drove down this innovative path.
Humans, on the other hand, have far more limited hearing, and we’re not great chirpers, either. And yet, it turns out we can learn this remarkable skill, too. In fact, research suggests it’s far more achievable than you might think—for the sighted and vision impaired alike!
Continue reading “Humans Can Learn Echolocation Too”
The Junk Machine Prints Corrupted Advertising On Demand
[ClownVamp]’s art project The Junk Machine is an interactive and eye-catching machine that, on demand, prints out an equally eye-catching and unique yet completely meaningless (one may even say corrupted) AI-generated advertisement for nothing in particular.
The machine is an artistic statement on how powerful software tools that have genuine promise and usefulness to creative types are finding their way into marketer’s hands, and resulting in a deluge of, well, junk. This machine simplifies and magnifies that in a physical way.
We can’t help but think that The Junk Machine is in a way highlighting Sturgeon’s Law (paraphrased as ‘ninety percent of everything is crud’) which happens to be particularly applicable to the current AI landscape. In short, the ease of use of these tools means that crud is also being effortlessly generated at an unprecedented scale, swamping any positive elements.
As for the hardware and software, we’re very interested in what’s inside. Unfortunately there’s no deep technical details, but the broad strokes are that The Junk Machine uses an embedded NVIDIA Jetson loaded up with Stable Diffusion’s SDXL Turbo, an open source AI image generator that can be installed and run locally. When and if a user mashes a large red button, the machine generates a piece of AI junk mail in real time without any need for a network connection of any kind, and prints it from an embedded printer.
Watch it in action in the video embedded below, just under the page break. There are a few more different photos on [ClownVamp]’s X account.
Continue reading The Junk Machine Prints Corrupted Advertising On Demand”
Electric Motors Run Continuously At Near-Peak Power
For a lot of electrical and mechanical machines, there are nominal and peak ratings for energy output or input. If you’re in marketing or advertising, you’ll typically look at the peak rating and move on with your day. But engineers need to know that most things can only operate long term at a fraction of this peak rating, whether it’s a power supply in a computer, a controller on an ebike, or the converter on a wind turbine. But this electric motor system has a unique cooling setup allowing it to function at nearly full peak rating for an unlimited amount of time.
The motor, called the Super Continuous Torque motor built by German automotive manufacturer Mahle is capable of 92% of its peak output power thanks to a unique oil cooling system which is able to remove heat and a rapid rate. Heat is the major limiter for machines like this; typically when operating at a peak rating a motor would need to reduce power output to cool down so that major components don’t start melting or otherwise failing. Given that the largest of these motors have output power ratings of around 700 horsepower, that’s quite an impressive benchmark.
The motor is meant for use in passenger vehicles but also tractor-trailer style trucks, where a motor able to operate at its peak rating would mean a smaller size motor or less weight or both, making them easier to fit into the space available as well as being more economically viable. Mahle is reporting that these motors are ready for production so we should be seeing them help ease the transportation industry into electrification. If you’re more concerned about range than output power, though, there’s a solution there as well so you don’t have to be stuck behind the times with fossil fuels forever.
Thanks to [john] for the tip!
