FOSDEM 2025, A Hardware Hacker’s Haven
Have you been to FOSDEM? It’s a yearly two-day megaconference in Brussels, every first weekend of February. Thousands of software and hardware hackers from all across Europe come here each year, make friends, talk software and hardware alike, hold project-specific meetups to drink beer and talk shop, and just have a fun weekend surrounded by like-minded people.
In particular, FOSDEM has free admission – drop by for the weekend, no need to buy entry tickets, just sort out your accomodation, food, travel, and visit for a day or two. I’ve covered FOSDEM quite extensively in 2023, so if you want to know more about how it works, I invite you to check out that article – plenty of stories, cool facts about FOSDEM, showcases, and so on. This year, I’ve also been to FOSDEM, it’s been pretty great, and I’d like to tell you about cool things I’ve seen happen during FOSDEM 2025.
FOSDEM is often described as an open software conference, and you might’ve had been fooled by this if you simply have checked the Wikipedia page. However, let me assure you – there’s always plenty of hardware, large amounts of it! This year, I feel like hardware has taken the spotlight in particular – let me show you at least some of it, so that you know what kinds of cool stuff you can expect and plan for in 2026.
Continue reading “FOSDEM 2025, A Hardware Hacker’s Haven”
Screenshot of the REPL running on the Flipper, importing the flipper API library and calling infrared receive function out of it with help of autocomplete
A MicroPython Interpreter For Flipper Zero
Got a Flipper Zero? Ever wanted to use a high-level but powerful scripting language on it? Thanks to [Oliver] we now have a MicroPython application for the Flipper, complete with a library for hardware and software feature support. Load it up, start it up, connect over USB, and you’ve got the ever-so-convenient REPL at your disposal. Or, upload a Python script to your Flipper and run them directly from Flipper’s UI at your convenience!
In the API docs, we’re seeing support for every single primitive you could want – GPIO (including the headers at the top, of course), a healthy library for LCD and LCD backlight control, button handling, SD card support, speaker library for producing tones, ADC and PWM, vibromotor, logging, and even infrared transmit/receive support. Hopefully, we get support for Flipper’s wireless capabilities at some point, too!
Check out the code examples, get the latest release from the Flipper app portal or GitHub, load it up, and play! Mp-flipper has existed for the better half of a year now, so it’s a pretty mature application, and it adds quite a bit to Flipper’s use cases in our world of hardware hacking. Want to develop an app for the Flipper in Python or otherwise? Check out this small-screen UI design toolkit or this editor we’ve featured recently!
Bits of GRUB syntax on pink background
Wake, Boot, Repeat: Remote OS Selection With GRUB And ESP
What do you do when you need to choose an OS at boot but aren’t physically near your machine? [Dakhnod]’s inventive solution is a mix of GRUB, Wake-on-LAN (WOL), and a lightweight ESP8266 running a simple HTTP server. In the past, [dakhnod] already enlightened us with another smart ESP hack. This one’s a clever combination of network booting and remote control that opens up possibilities beyond the usual dual-boot selector.
At its core, the hack modifies GRUB to fetch its boot configuration over HTTP. The ESP8266 (or any low-power device) serves up a config file defining which OS should launch. The trick lies in adding a custom script that tells GRUB to source an external config:
#!/usr/bin/env cat
net_dhcp
source (http,destination_ip_or_host:destination_port)/grub/config
Since GRUB itself makes the HTTP request, the system needs a running web server. That could be a Raspberry Pi, another machine, or the ESP itself. From there, a WOL-enabled ESP button can wake the PC and set the boot parameters remotely.
Is it secure? Well, that depends on your network. An open, unauthenticated web server dishing out GRUB configs is risky, but within a controlled LAN or a VLAN-segmented environment, it’s an intriguing option. Automation possibilities are everywhere — imagine remotely booting test rigs, toggling between OS environments for debugging, or even setting up kiosk machines that reconfigure themselves based on external triggers.
For those looking to take it further, using configfile instead of source allows for more dynamic menu entries, although it won’t persist environment variables. You could even combine it with this RasPi hack to control the uptime of the HTTP server. The balance between convenience and security is yours to strike.
If you’ve got your own wild GRUB customisation, let’s hear it!
