It’s SSB, But Maybe Not Quite As You Know It
Single Sideband, or SSB, has been the predominant amateur radio voice mode for many decades now. It has bee traditionally generated by analogue means, generating a double sideband and filtering away the unwanted side, or generating 90 degree phase shifted quadrature signals and mixing them. More recent software-defined radios have taken this into the CPU, but here’s [Georg DG6RS] with another method. It uses SDR techniques and a combination of AM and FM to achieve polar modulation and generate SSB. He’s provided a fascinating in-depth technical explanation to help understand how it works.
The hardware is relatively straightforward; an SI5351 clock generator provides the reference for an ADF4351 PLL and VCO, which in turn feeds a PE4302 digital attenuator. It’s all driven from an STM32F103 microcontroller which handles the signal processing. Internally this means conventionally creating I and Q streams from the incoming audio, then an algorithm to generate the phase and amplitude for polar modulation. These are fed to the PLL and attenuator in turn for FM and AM modulation, and the result is SSB. It’s only suitable for narrow bandwidths, but it’s a novel and surprisingly simple deign.
We like being presented with new (to us at least) techniques, as it never pays to stand still. Meanwhile for more conventional designs, we’ve got you covered.
An excerpt from the website, showing the nRootTag block diagram and describing its structure
Hijacking AirTag Infrastructure To Track Arbitrary Devices
In case you weren’t aware, Apple devices around you are constantly scanning for AirTags. Now, imagine you’re carrying your laptop around – no WiFi connectivity, but BLE’s on as usual, and there’s a little bit of hostile code running at user privileges, say, a third-party app. Turns out, it’d be possible to make your laptop or phone pretend to be a lost AirTag – making it and you trackable whenever an iPhone is around.
The nroottag website isn’t big on details, but the paper ought to detail more; the hack does require a bit of GPU firepower, but nothing too out of the ordinary. The specific vulnerabilities making this possible have been patched in newer iOS and MacOS versions, but it’s still possible to pull off as long as an outdated-firmware Apple device is nearby!
Of course, local code execution is often considered a game over, but it’s pretty funny that you can do this while making use of the Apple AirTag infrastructure, relatively unprivileged, and, exfiltrate location data without any data connectivity whatsoever, all as long as an iPhone is nearby. You might also be able to exflitrate other data, for what it’s worth – here’s how you can use AirTag infrastructure to track new letter arrivals in your mailbox!
Make Your Own Air Knife And Air Amplifier
Want to make your own air knife to cut things with? Unfortunately that’s not what these devices are intended for, but [This Old Tony] will show you how to make your own, while explaining what they are generally intended for.  His version deviates from the commercial version which he got his hands on in that he makes a round version instead of the straight one, but the concept is the same.
In short, an air knife is a laminar pressurized airflow device that provides a very strong and narrow air pattern, using either compressed air or that from a blower. Generally air knives will use the Coandă effect to keep the laminar flow attached to the device for as long as possible to multiply the air pressure above that from the laminar flow from the air knife itself. These are commonly used for cleaning debris and dust off surfaces in e.g. production lines.
As [Tony] shows in the disassembly of a commercial device, they are quite basic, with just two aluminium plates and a thin shim that creates the narrow opening through which the air can escape. The keyword here is ‘thin shim’, as [Tony] discovers that even a paper shim is too thick already. Amusingly, although he makes a working round air knife this way, it turns out that these are generally called an air amplifier, such as those from Exair and are often used for cooling and ventilation, with some having an adjustable opening to adjust the resulting airflow.
Some may recognize this principle for those fancy ‘bladeless’ fans that companies like Dyson sell, as they use essentially the same principle, just with a fan providing the pressure rather than a compressor.
Continue reading “Make Your Own Air Knife And Air Amplifier”
Here’s A Spy Movie-Grade Access Card Sniffing Implant
Some of our devices look like they’re straight out of hacker movies. For instance, how about a small board you plant behind an RFID reader, collecting access card data and then replaying it when you next walk up the door? [Jakub Kramarz] brings us perhaps the best design on the DIY market, called The Tick – simple, flexible, cheap, tiny, and fully open-source.
Take off the reader, tap into the relevant wires and power pins (up to 25V input), and just leave the board there. It can do BLE or WiFi – over WiFi, you get a nice web UI showing you the data collected so far, and letting you send arbitrary data. It can do Wiegand like quite a few open-source projects, but it can also do arbitrary clock+data protocols, plus you can just wire it up quickly, and it will figure out the encoding.
We could imagine such a board inside a Cyberpunk DnD rulebook or used in Mr Robot as a plot point, except that this one is real and you can use it today for red teaming and security purposes. Not to say all applications would be NSA-catalog-adjacent pentesting – you could use such a bug to reverse-engineer your own garage door opener, for one.
Sensory Substitution Device Tingles Back Of Your Hand
A team from the University of Chicago brings us a new spin on sensory substitution, the “Seeing with the Hands” project, turning external environment input into sensations. Here specifically, the focus is on substituting vision into hand sensations, aimed at blind and vision disabled. The prototype is quite inspiration-worthy!
On the input side, we have a wrist-mounted camera, sprinkled with a healthy amount of image processing, of course. As for the output, no vibromotors or actuators are in use – instead, tactile receptors are stimulated by passing small amounts of current through your skin, triggering your touch receptors electrically. An 5×6 array of such “tactile” pixels is placed on the back of the hand and fingers. The examples provided show it to be a decent substitution.
This technique depends on the type of image processing being used, as well as the “resolution” of the pixels, but it’s a fun concept nevertheless, and the study preprint has some great stories to tell. This one’s far from the first sensory substitution devices we’ve covered, though, as quite a few of them were mechanical in nature – the less moving parts, the better, we reckon!
Deep Space DX Hack Chat
Join us on Wednesday, March 5 at noon Pacific for the Deep Space DX Hack Chat with David Prutchi!
In the past 70-odd years, the world’s space-faring nations have flung a considerable amount of hardware out into the Void. Most of it has fallen back into Earth’s gravity well, and a lot of what remains is long past its best-by date, systems silenced by time and the harsh conditions that rendered these jewels of engineering into little more than space flotsam.
Luckily, though, there are still a few spacecraft plying the lonely spaces between the planets and even beyond that still have active radios, and while their signals may be faint, we can still hear them. True, many of them are reachable only using immense dish antennas.
join-hack-chatNot every deep-space probe needs the resources of a nation-state to be snooped on, though. David Prutchi has been listening to them for years using a relatively modest backyard antenna farm and a lot of hard-won experience. He’s been able to bag some serious DX, everything from rovers on Mars to probes orbiting Jupiter. If you’ve ever wanted to give deep space DX a try, here’s your chance to get off on the right foot.
Our Hack Chats are live community events in the Hackaday.io Hack Chat group messaging. This week we’ll be sitting down on Wednesday, March 5 at 12:00 PM Pacific time. If time zones have you tied up, we have a handy time zone converter.
A plugged-in 12VHPWR cable, with two thermistors inserted into the connector shell, monitoring for heat
12VHPWR Watchdog Protects You From Nvidia Fires
The 12VHPWR connector is a hot topic once again – Nvidia has really let us down on this one. New 5080 and 500 GPUs come with this connector, and they’re once again fire-prone. Well, what if you’re stuck with a newly-built 5080, unwilling to give it up, still hoping to play the newest games or run LLMs locally? [Timo Birnschein] has a simple watchdog solution for you, and it’s super easy to build.
All it takes is an Arduino, three resistors, and three thermistors. Place the thermistors onto the connector’s problematic spots, download the companion software from GitHub, and plug the Arduino into your PC. If a temperature anomaly is detected, like one of the thermistors approaching 100C, the Arduino will simply shut down your PC. The software also includes a tray icon, temperature graphing, and stability features.  All is open-source — breadboard it, flash it. You can even add more thermistors to the mix if you’d like!
This hack certainly doesn’t just help protect you from Nvidia’s latest creation – it can help you watch over any sort of potentially hot mod, and it’s very easy to build. Want to watch over connectors on your 3D printer? Build one of these! We’ve seen 12VHPWR have plenty of problems in the past on Nvidia’s cards – it looks like there are quite a few lessons Nvidia is yet to learn.
