Why 56k Modems Relied On Digital Phone Lines You Didn’t Know We Had
If you came of age in the 1990s, you’ll remember the unmistakable auditory handshake of an analog modem negotiating its connection via the plain old telephone system. That cacophony of screeches and hisses was the result of careful engineering. They allowed digital data to travel down phone lines that were only ever built to carry audio—and pretty crummy audio, at that.
Speeds crept up over the years, eventually reaching 33.6 kbps—thought to be the practical limit for audio modems running over the telephone network. Yet, hindsight tells us that 56k modems eventually became the norm! It was all thanks to some lateral thinking which made the most of the what the 1990s phone network had to offer.
Continue reading “Why 56k Modems Relied On Digital Phone Lines You Didn’t Know We Had”
The Future We Never Got, Running A Future We Got
If you’re familiar with Java here in 2025, the programming language you know is a world away from what Sun Microsystems planned for it in the mid-1990s. Back then it was key to a bright coffee-themed future of write-once-run-anywhere software, and aside from your web browser using it to run applications, your computer would be a diskless workstation running Java bytecode natively on the silicon.
What we got was slow and disappointing Java applets in web pages, and a line of cut-down SPARC-based JavaStations which did nothing to change the world. [FatSquirrel] has one of these machines, and a quarter century later, has it running NetBSD. It’s an interesting journey both into 1990s tech, and some modern-day networking tricks to make it happen.
These machines suffer as might be expected, from exhausted memory backup batteries. Fortunately once the serial port has been figured out they drop you into an OpenBoot prompt, which, in common with Apple machines in the ’90s, gives you a Forth interpreter. There’s enough info online to load the NVRAM with a config, and the machine stuttered into life. To do anything useful takes a network with RARP and NFS to serve an IP address and disk image respectively, which a modern Linux machine is quite happy to do. The resulting NetBSD machine maybe isn’t as useful as it could be, but at risk of angering any Java enthusiasts, perhaps it’s more useful than the original JavaOS.
We remember the promise of a Java-based future too, and tasted the bitter disappointment of stuttering Java applets in our web pages. However, given that so much of what we use now quietly runs Java in the background without our noticing it, perhaps the shade of Sun Microsystems had the last laugh after all. This isn’t the first ’90s machine that’s been taught new tricks here, some of them have received Java for the first time.
Closeup of a rackmounted custom HiFi setup
Rackmount All The Things, Hi-Fi Edition
For those who love systems and structure, owning a 19-inch rack with just one slot filled is just not it. But what if the rest of your gear isn’t 19-inch? Well, then you go out and make it so, just like [Cal Bryant] did recently.
The goal was to consolidate multiple devices — DAC, input selector, streamer, and power routing — into a single 2U rackmount unit. His first attempts involved drilling 1U panels to attach gear with removable faceplates. That worked, but not all devices played nice. So his next step became a fully custom enclosure with CAD-modeled brackets and front panels.
OpenSCAD turned out to be a lifesaver, letting [Cal] design modular mounting solutions. Exporting proper circles for CNC turret punching however appeared to be a nightmare. It was FreeCAD to the rescue for post-processing. After some sanding and auto-shop painting, the final faceplate looked factory-made.
Custom switch boxes for power and audio routing keep things tidy, housing everything from USB to XLR inputs. A 4-pole switch even allows seamless swapping between his DAC and DJ controller, while UV-printed graphics bring the finishing touch to this project. For those looking to clean up their Hi-Fi setup (or just love modding for the sake of it), there’s a lot to learn from this build.
If buying a rack is not within your budget, you could start with well-known IKEA LACK furniture.
