Linux Fu: Use The Source (Command), Luke
You can argue if bash is a good programming language or not, but you can’t argue that it is a programming language. However, there are a few oddities about it that make it different from most other languages you probably know. For one thing, variables are dynamically scoped. Second, you can easily change variables in an upper scope. This leads to a problem when you want to do something like reset your path:
#!/bin/bash
#: This does NOT work
PATH=/usr/bin:/bin
Well, actually, it does work; it just doesn’t work the way you imagine it might. The key is to realize that when you execute our script (say, resetpath), a new copy of bash runs. It inherits all the variables from your shell. Now the script sets PATH for the new copy of bash. Anything else you run in that script will see your change. But when the script exits, the new copy of bash is gone and the old copy sees the same old PATH it always did.
Sometimes, this is a benefit, similar to “call by value” in other languages. However, what if you want to influence things? What’s more is that the situation is just the opposite within bash functions. For example:
#!/bin/bash
b() {
  echo B: $x
  x=200
a() {
  x=100
  b
  echo A: $x
a
#: output
#: B: 100
#: A: 200
Function b has no difficulty reading and even setting variable x.
The Answer, Of Source Course
The answer to the first problem is to use the source command (which can be either the word source or a single period). This tells bash to avoid running a new interpreter and just pretend you’d entered all the lines in a file from the console.
This is great sometimes. Our resetpath script will actually work just fine with either of these commands:
source resetpath
. resetpath
You don’t even need the #! line, although it doesn’t hurt. However, there are a few problems.
The Catches
First, if you exit, then you exit the entire shell, not something you probably meant to do. Second, you wind up polluting the variable space of the parent. For example, if your script creates a function X, with a regular shell script, that function goes away as soon as your script stops. With a source script, function X now will live forever unless you do something about it.
Neither of these problems are insurmountable, of course, and you’ll see a few ways to address it in the example code in this post.
A Simple Example
If you spend a lot of time on the command line, you might want to have shortcut names for directories. What’s more, you might want to execute a little script when you go to particular directories or even when you leave them.
My plan is to keep a simple file in ~/.proj_dirs. To keep things simple, I’m assuming you can figure out the bash format:
PROJ_DIRS["docs"]="~/library/documents"
PROJ_DIRS["video"]="~/library/videos"
PROJ_DIRS["arduino"]="/home/alw/projects/embedded/Arduino"
The eventual goal is to replace the cd command (or, at least, allow for that). However, it would be a pain to have to write something like “source pcd arduino” every time.
The Alias Solution
The answer is pretty simple. You can create a script that can install itself as an alias. Here’s the basic flow:
#!/bin/bash
#: This is not a bash shell script
#: But needs to be sourced. However...
#: Try:
#: eval $(__project_dir.sh --__install project_dir)
if [ "$1" == "--__install" ] # this should only be called from "real" script
then
   aname="$2"
   if [ "$aname" == "" ]
   then
      aname="pcd"
    fi
    echo -n "alias '$aname'='source "
    aname=$(realpath -s "$0")
    echo "$aname'"
    exit 0
fi
#: Your source script goes here
The idea is that if you run as a regular script with –__install, it returns the alias command. You can then eval that in, for example, a startup script (like .bashrc or .profile), and then you’ll have the alias you want. By default, the code uses pcd, although you can set up any name you like on the command line. You could even create an alias for cd if you wanted to do that.
Why Not Automatic?
You could, of course, detect if you were running normally or as a source automatically. Turns out this is somewhat finicky across shells, although if you are sure you are always using real bash, it is feasible. For example:
if [[ "${BASH_SOURCE[0]}" == "$0" ]]
then
   echo I am not sourced!
fi
Variables
Once you have the basic framework, it is easy to write the scripts to read the “database” (also using source) and do the actual work. However, there is a slight problem. Once you produce all the variables you need to do the work, it leaves all that pollution in your shell’s namespace.
Of course, you could write a function to clean up everything you use, but that’s a pain and error prone, too. A better idea is to write your code in a bash function. Then you can use local variables that will go away when the function returns. That leaves you with just your function to clear up with unset.
That leads to this simple framework:
#!/bin/bash
then
   then
      aname="$2"
      then
        aname="pcd" # default alias name
      fi
      echo "$aname'"
      exit 0
   fi
   echo "You must source this script"
   exit 1
fi
#: Ok your script goes here
main() {
#: Be sure to have this at the end
#: Actually named with underscores in the real code
#: But that upsets the rendering in browser
#: Actual code at https://gist.github.com/wd5gnr/c5681f2f7072938d5d7afe7a1e3e9132
go() {
   local tmprv
   main "$@"
   tmprv=$?
   unset main, go
   return $tmprv
go "$@"
return $?
The very bottom calls the go function, which calls your main function. Then the go function destroys your main function and itself. If you create new functions that you don’t want to keep around, you’ll need to destroy them yourself. Besides, you might be creating functions you want to keep, so the framework can’t decide.
The Whole Thing
You can find the entire example on GitHub. Outside of the management of the alias and the variable scope, the script is unremarkable. Note the optional scripts in the directories (.dir_enter and .dir_exit) are sourced also, so they only need to be readable (-r) not executable (-x).
The only other nuance is that if you enter anything as a directory that the program doesn’t recognize, it assumes it is an actual directory, so you can use this to replace the cd command entirely if you want.
Since the script can tell if it is sourced or not, it is possible to start in the source mode and then call yourself as a normal script to do work where that makes more sense. As usual with bash, there are lots of possibilities.
We talk about bash programming a lot around here. Debugging can be helpful, although they haven’t packaged the debugger for newer versions of bash lately.
12 thoughts on “Linux Fu: Use The Source (Command), Luke
  1. The new comment spam filter is broken. You need to change your Akismet config on hackaday so that it lets people post links in comments. Or at the very least tells them when they’re being blocked instead of making it unclear if the comment post went through or not.
  2. Love the way this was written. Even though I know and use bash somewhat regularly I learned a few things. I’d love to see more content like this!
  3. Or you could just use zsh, which is universally better than bash, and do:
    hash -d arduino=/home/alw/projects/embedded/Arduino
    so that you can then just do:
    cd ~arduino
    (See zshexpn(1): “named directories”)
  4. I believe the “export” command solves the problem of putting variables like PATH in the environment without the complications of using “source”.
    1. export goes the opposite direction.
      Export sends a variable in to script or other child process. So you can do:
      export flavor=chocolate
      ./make-ice-cream.sh
      Sourcing would be used the other way around:
      . get-flavor.sh
      echo $flavor
  5. If you plan on using the command or any of the other set-ups described, consider adding these to your ~/.bashrc or ~/.profile or ~/.bash_profile script as appropriate.
    These execute on login (.bashrc does NOT execute on non interactive logins, i.e. connecting via .
  6. It’s great to see what people do to customize their home/work place(s) :)
    You might check out direnv (first hit on google, or direnv + net or on github + direnv) – it seems to do most/all of what you’re trying out here… it’s in many distros and brew on macs can install it… as it says, “It augments existing shells with a new feature that can load and unload environment variables depending on the current directory” (you can also place commands to execute on entering a dir, etc.)
    Keep up da scriptin’!
  7. I try to stay away from bashing as much as possible. Just me though. Great to use when you have a sequence of say ‘rsync’ commands for a backup script, but more complicated than that and the Python or Perl tool is used for a more readable script.
  8. Reminded me of the scariest story in 2 words I’ve read on lemmy: source ~/.bash_history. [For the uninitiated, it’ll re-run every single command you have saved in you history backwards. Simple. Chaotic. Destructive.]
  9. “You can argue if bash is a good programming language or not, but you can’t argue that it is a programming language.”
    If you can’t argue that it’s a programming language then ipso facto you can’t argue either side about it being a good programming language.
Leave a Reply to lightislightCancel reply
