Exploring VersaLOGIC Pre-LSI Logic Cards With The Data/620
Before the era of large-scale integration (LSI) semiconductor circuits, discrete logic circuits using the common diode-transistor logic (DTL) were still necessary and available in a format that was modular and reusable. [David Lovett] over at the Usagi Electric farm has two great examples that date back to the 1950s and 1960s, showing the jump in technology over the course of a mere decade.
The newer Varian Data Machines 620 from 1966 uses germanium diodes and transistors, while the 1956 Bendix G-15 uses germanium diodes with vacuum tubes, the latter effectively fulfilling the same purpose as the transistors. The main difference between the modules is the density, with a decade of technological improvements allowing for more than double the logic on similarly sized cards and a similarly impressive reduction in power usage.
Currently, [David] is working on reverse-engineering these so-called VersaLogic modules to be able to troubleshoot the Data/620 machine in his possession. The results of these efforts are being published on GitHub. Although you can think of these modules as more or less big versions of the 7400-logic ICs — which began to replace them in the Data/620I from 1967 — some of the circuits on the cards get pretty complex.
With hundreds of these VersaLogic cards in one Data/620 computer, finding a few dodgy germanium diodes and transistors on them is quite the struggle. Whereas the Bendix G-15 helpfully provided a semi-automatic tester for the modules, no such option appears to be exist for these VersaLogic cards, leaving [David] to make his own version if he ever wants to see this 1960s machine that was once used at NASA roar back to life, and possibly read out what’s stored in the magic core memory.
This debugging process is complicated by the fact that these aren’t your basic 5V TTL-style logic cards, but rather use -12- and 0V-based high-threshold logic (HTL). Developing testing logic and hardware for these cards, which also takes into account the bidirectional nature of some of these cards, is a bit of a challenge. Fortunately, the Usagi Electric community is on the job, and you’re cordially invited to hop over to the official Discord channel to pitch in if that’s your thing.
We always enjoy thinking of different ways to implement logic. Even the really bizarre ones.
3 thoughts on “Exploring VersaLOGIC Pre-LSI Logic Cards With The Data/620
  1. @04:30 Mr Usagi is tracking over the PCB in Krita. You can also directly import the images in KiCad and trace over them in KiCad. The big advantage is that you can also put the transistors on the PCB, and DRC will catch any mistakes you make. But Mr. Usagi gets a lot of comment on youtube (650 already), and just in the last day this has already been mentioned 6 times. I wonder how many people read those comments.
    @15:44 Similar for the 47pF capacitors. These are to speed up the logic, and not for noise suppression. This has also already been mentioned in the comment on youtube.
    @21:55 For 5V logic to -12V logic and designing a test card. Also plenty of options on youtube from using CMOS logic (fragile, drive current?) to using RS232 (or similar) driver IC’s. With a bunch of DAC’s you can test more / deeper and this has also already been mentioned. And simple BJT’s. Similarly, you can use comparators (LM393 (open collector) or opamps LM358) Plenty of options here.
    @19:45 For mapping out the wiring, you can build something like a cable tester, or even simply a bunch of PCB’s which route all data lines to LED’s.
Leave a Reply to PeterCancel reply
