Keep That Engine Running, With A Gassifier
Every now and then in histories of the 20th’s century’s earlier years, you will see pictures of cars and commercial vehicles equipped with bulky drums, contraptions to make their fuel from waste wood. These are portable gas generators known as gasifiers, and to show how they work there’s [Greenhill Forge] with a build video.
A gasifier on a vintage tractor
A gasifier on a vintage tractor. Per Larssons Museum, CC BY 2.5.
When you burn a piece of wood, you expect to see flame. But what you are looking at in that flame are the gaseous products of the wood breaking down under the heat of combustion. The gasifier carefully regulates a burn to avoid that final flame, with the flammable gasses instead being drawn off for use as fuel.
The chemistry is straightforward enough, with exothermic combustion producing heat, water vapour, and carbon dioxide, before a further endothermic reduction stage produces carbon monoxide and hydrogen. He’s running his system from charcoal which is close to pure carbon presumably to avoid dealing with tar, and at this stage he’s not adding any steam, so we’re a little mystified as to where the hydrogen comes from unless there is enough water vapour in the air.
His retort is fabricated from sheets steel, and is followed by a cyclone and a filter drum to remove particulates from the gas. It relies on a forced air draft from a fan or a small internal combustion engine, and we’re surprised both how quickly it ignites and how relatively low a temperature the output gas settles at. The engine runs with a surprisingly simple gas mixer in place of a carburetor, and seems to be quite smooth in operation.
This is one of those devices that has fascinated us for a long time, and we’re grateful for the chance to see it up close. The video is below the break, and we’re promised a series of follow-ups as the design is refined.
53 thoughts on “Keep That Engine Running, With A Gassifier
  1. I’ve gone down the gassifier rabbit hole a few times over the years, though I have yet to build one myself.
    They were apparently fairly common in England during WWII, especially for things like tractors, as gasoline was obviously highly rationed for war use.
    The biggest downside from what I see is you either need to run the gassifier and use the fuel it produces immediately (I have seen one example from the WWII era of a car pulling a trailer with a gassifier running on it), or store the results in low pressure gaseous form, which is obviously extremely space inefficient. Because of the wide variety of molecules present in the gas, liquification is not really achievable, and even pressurization has major challenges.
    Tar buildup is another major issue, as mentioned. But still, very cool tech. If I had more time and funds to mess around with this stuff I’d love to get a setup going someday.
    1. If I remember correctly, carbon monoxide starts to polymerize under pressure in the presence of iron.
      This has lead to some accidents when people have tried to store syngas in steel containers under pressure, because the result will be fine carbon dust and oxygen gas, and hydrogen and the other stuff. It can go boom.
    2. and even pressurization has major challenges.
      Apparently CO will attack metals such as iron, nickel, copper, etc. under elevated pressures and temperatures, and hydrogen will speed up the process. It produces metal carbonyls, some of which are pyrophoric (spontaneously combusting in air). It corrodes the walls of metal tanks and pumps/piping. The combined effect is a risk of leaks, tank rupture and explosions, since the carbonyls may spontaneously ignite when you let it out of the tank and introduce it to air.
      The earlier post where I speculated about oxygen formation in a steel tank was wrong, but that was removed.
  2. There’s a quite funny Swedish facebook group with some enthusiasts building an ecosystem around this. Incidentally, Sweden has a lot of wood, not to mention growing petrol and electricity prices.
    First, they make their own coal, including some very large “cookers” or whatever they call it to make a lot of it, optimizing the burn. The coal apparently makes less of a messy/cloggy experience in the engine than pure wood. Then, they adjust cars to run on said coal, trying to optimize the design. Last time I checked they were making electricity from a generator powered by coal, trying to optimize that process . Haven’t checked in for a while, maybe they’re onto the next thing, whatever that would be.
    1. Yeah, running gasifiers on charcoal is underrated; saves a lot of complexity because you don’t have to deal with water vapor or tar. You lose a significant chunk of the energy in the wood, but it’s a much cleaner process overall.
  3. we’re a little mystified as to where the hydrogen comes from unless there is enough water vapour in the air.
    It would be rare to have completely dry ambient air and completely dry fuel once it’s been sitting around for a while. As long as there is moisture there will be some hydrogen. You might also just sprinkle some water on top to get moisture in the fuel.
    There’s also some tar left in the charcoal which would also contain some water. The tar is converted to gases in the combustion zone, then break down in the combustion and reduction zones and also produce other stuff like methane, but then the gases pass through a cooler area and the charcoal there will off-gas tar and water vapor, and some air will be bypassing the combustion zone through the upper section of the box. A better burner design would limit this. In more advanced designs there’s also a shaker that keeps the charcoal bed and the ashes moving, so you don’t form channels or voids and bridges in the burning fuel.
    1. Tar is a problem in the entire fuel system, not just the cylinders.
      It will condense inside the fuel lines when the gas cools down as it heads toward the cylinder.
      It clogs everything.
      The fuel lines.
      The gas mixer.
      The valves.
      Burning straight wood is a valuable option if you get into a “we literally cannot get a better fuel and we need to run this NOW” situation, like running a tractor during wartime.
      But it’s almost always a bad idea otherwise because you are introducing an order of magnitude more maintenance.
      If you need to rebuild your engine once a week to stop starvation it is a great option.
      But otherwise? Now way. Better to spend that effort to make and store cleaner fuel.
      Charcoal in this case.
      1. A gasifier tar trap is a component designed to remove tar, a sticky, high-molecular-weight hydrocarbon contaminant, from the syngas (producer gas) produced during biomass gasification. These traps use methods like mechanical filtering, wet scrubbing, char bed adsorption, or catalytic processes to prevent tar from damaging downstream equipment or contaminating the syngas
      2. Burning wood is a big value proposition, because the energy density is higher than charcoal and it produces a gas mixture that burns with more air, hence more power out of the engine. Back in the day charcoal was used in towns because it emits less smoke, but all the trucks hauling stuff had to use wood to get up hills. The power you get out of a wood gas engine is pretty marginal anyways, so you often needed a bit of gasoline to pick it up.
        A cubic meter of wood chunks or pellets contains about 2000 kWh and 70% of that can be recovered through the gasifier, so a relatively modest sized hopper is enough for a truck or a tractor. That’s roughly equivalent to 40 gallons or 150 liters of gasoline, which gets you pretty far.
        Meanwhile, wood charcoal contains 20-30% less energy per cubic meter, which in itself is not a major issue, but then you need about 2-3 times the wood to cook the charcoal, so that represents a massive waste of energy. Your original cubic meter of wood goes down from 2000 kWh to about 500 kWh at worst,
        1. Bamboo pellets have a higher calorific value (around 20.1MJ/kg vs. wood’s 16MJ/kg), lower ash content (comparable to wood), and are more sustainable due to their fast growth rate.
          An acre of managed pine only produces around 1.6 tons of dry weight wood per year of growth.
          A single acre of bamboo will produce 5-7 tons of fuel pellets per year without significant effort. Using specialized clones, like Beema Bamboo, when grown with high-density planting and precision farming methods, can achieve Up to 40 tons per acre per year.
          1. Most of the reason why pine, birch, oak, etc. produce limited yields is because they’re growing in the colder regions of the world where bamboo doesn’t. Beema Bamboo is grown in the tropics, particularly in Southeast Asia, India and Africa.
            I suppose you could ship it elsewhere, but that would defeat the point.
          2. Its not a big mystery, Trees are slower growing than grasses. EVEN in the tropics.
            Most of the reason why pine, birch, oak, etc. produce limited yields is because they’re slow growing compared to bamboo.
            I live in USDA zone 9a, Definitely NOT a colder part of the world. We grow LOTS of pine trees here over 5.2 million acres with a growing volume of nearly 7 billion cubic feet of loblolly pine forests alone, and pine makes up 85% of its softwood timber production, totalling about 25 billion board feet.
            As to your claims on pines calorific content…
            Dried pine has a calorific value that typically ranges from about 14 to 21 MJ/kg, with specific values depending on factors like moisture content, part of the tree (wood, needles, bark), and species. For example, air-dried spruce, a member of the pine family (Pinaceae) has a value of 14–17 MJ/kg, while its dry wood has a calorific value of around 16.9 MJ/kg. Other pine materials can have higher values, such as pine bark at 21 MJ/kg or torrefied pine sawdust at 22.35 MJ/kg
            But returning to bamboo….
            The hardiest varieties of bamboo are suitable for USDA zones 5-10. Hardly isolated to the tropics. But even Beema bamboo, which is best suited for tropical and subtropical climates (USDA Zones 8A-11), is cold-hardy down to about 25-30F, making it viable in warmer parts of Zones 6 and 7 with appropriate protection.
          3. It doesnt have to hit 40 tons per acre. Thats not the threshold of viability, thats the extraordinary example of a specific strains top production.
            It only has to top woods 1.6 tons per acre, which it does easily in ANY climate that it grows.
          4. The fact that bamboo doesn’t die in winter is not a good thing.
            Never plant bamboo.
            Not in an an isolated swamp full of mirelurks, surrounded by an apocalyptic wasteland of glowing concrete.
            If your neighbor plants bamboo, kick him/her square in the crotch.
    2. Charcoal is not a single, pure chemical compound. It’s a porous, carbon-rich material left over from heating organic matter without oxygen. Its exact composition, including the precise amounts of hydrogen, oxygen, and other impurities, varies depending on the source material and the charring process.
      C₇H₄O is sometimes used as an empirical or approximate formula for charcoal in specific contexts, such as for gunpowder, because it accounts for the small amounts of hydrogen and oxygen that are present as impurities. The true composition varies depending on the source material and how it was charred
  4. The actual answer is that pressurized CO in steel tanks carburizes the steel, making it brittle, and corrodes the tank from the inside by rusting, then the pressure ruptures the tank. Apparently no free oxygen is produced since it would be consumed by the iron.
  5. The comments go jumping all over the place again…
    The actual effect is that CO makes steel brittle and causes it to rust, which ruptures the tank from the pressure.
  6. I always see this used with vehicles, but have thought a much better use would be with an emergency generator. Any disaster big enough to require its use would leave plenty of wood lying around.
    1. True, but solar is a much easier option for emergency power nowadays. One of those battery box “solar generators” with fold-up panels has served me well. Saves the effort of gathering/processing/drying fuel when you probably have a lot of other things you need to be doing, in an emergency/disaster situation. Takes advantage of the clear skies after a hurricane, as well.
        1. Read ‘I Pony’ by Vermin Supreme.
          Zombies are a perfect energy source.
          Defy the laws of thermodynamics.
          Vermin is a visionary genius!
      1. I see emergency generators as something you can use immediately and not wait until the next afternoon to charge up batteries. If you can pull a cord to start to get power now, it’s an emergency generator – if you can wait for hours and hours, where’s the emergency?
  7. I worked for a place that built induction heaters. We used one to melt a few pounds of aluminum on my buddies stovetop, that was covered here. One of our clients had built a semi functioning system around one of our 2.4kw heaters and a largish pipe Tee fitting so in theory the cap could be pulled off and more raw material added in as needed. It was interesting for sure but..
    You had to start and run it on gas for a while to get it hot enough to get any gasses out of the wood, and the generator barely made enough power to run the induction heater.
    I think the sanest approach would be something like a firepit under the gasifier to get it started, and to use the gas to power a turboshaft engine, and use the exhaust from that to keep the gasifier going.
    Almost John Hartford’s idea of a genuine old fashioned Steam Powered Aereo Plane
    BTW even if you do not use the wood gas it is so worth it to make your own cooking charcoal.
      1. The finns had a working wood gas truck with a blower before ww2. Power output of the engine was a few % less than the unaspirated gasoline output. The devil is in the maintenance. They never could get it to work reliably in the long run.
    1. For several years New York State college at Morrisville (IIRC) had a small demo wood gas unit running a generator at the NYS Woodsman’s Field Days in Central New York. I think it was 20KW (don’t remember if that was electrical output or engine rating). I couldn’t find a link in a quick search but it was a nice unit with a periodic shaker and ran on wood chips.
  8. Since my country’s political leaders are completely corrupted by the net zero nonsense it’s a matter of time before petrol and diesel and natural gas are banned.
    IDI engines will see a resurgence, burning waste process oils.
    Gasification tech will improve.
    Will be chuckling when the lights go out for a week or more in mid winter during a spell of cloudy weather with no wind.
  9. Seems to me like a steam generator already would have a better energy output from burning wood. Let’s just burn some wood to make clean hydrogen that we can store. New tech meets old.
    1. Steam better than ice? Oh boy, you can’t imagine how wrong you are. And this is coming from someone who owns a Steam tractor 1/10 replica in working condition since kid
      1. I believe the point the gentleman tried to make included the effort of making the fuel, running and maintaining the device. A steam engine would be less challenging to keep operating than a wood gas device, with all its little tarring habits and ash flows. Additionally, you can run a steam engine on proper arm or leg thick logs, that wont work well with a wood gasifier.
        1. Thanks for explaination, but Again, no, in all point of view : construction, cost, maintenance, efficiency, daily use.i will not even comment more on it because It’s basic engineering knowledge and infos are easy to find.
  10. I’ve went to the raw wood gazifier direction and went for charcoal gazifier. I see raw wood like crude oil and charcoal like refined gazoline.
    We’ve plenty of boat running on crude oil, i’ve worked on a boat able to use crude oil or gazoil. The chef engineer would have kill me when if i spoke one more time about bunkering crude oil. You need a boiler, high maintance, it’s a mess … Same thing for wood and charcoal…
    In a raw wood gazifier, the wood is first charred and the charcoal produce the gaz. You have to keep a sharp condition of temperature and depression to burn all the tar coming from charring the wood. well cooked charcoal don’t have tar, one of the best side of the dark side of gazifier : you never size carb or valves. With a raw wood gazifier, if something goes south, first thing to producer is tar, and you see it the next startup of the engine, when is too late. Don’t ask how i know…cleaning syngaz with tar is a pain. A charcoal gazifier “only” need filtration for dust and cooling.
    another difference: charcoal gazifier can be made in few hours, sometimes minutes, depending of your need for bells and whistles, like water injection, with very few things . Onr of my favorite is made of a propane tank with a hatch to refill and 2 smal tubes for the inlet of air and the outlet of syngaz.
    The charcoal can be made out of twigs, usualy considered like a waste and burned on site. easy to do in a simply 220l barrel or tub( the old ones, in cast iron), or make a kiln in few hours. Better, Some heating wood boiler produce a lot of charcoal as a “waste”.
    Startup Time in a charcoal gazifier is unbeatable : 2 mn and you ready to go… I’ve never eared of a raw wood gazifier starting in less than 15mn from a cold start.
    i use it in a weekly basis (on average, along the year, more in winter than in summer),since 4 years to power a generator. Simple and easy
  11. There is a company in Berkeley CA called “All Power Labs” that has been building and selling turn-key gasifier electrical generators for some time now and they even retrofitted a car for a race to Las Vegas, if I remember correctly. They seem to have solved a lot of the reliability problems discussed here. Their target market seems to be rural agicultural areas with lots of excess bio mass and little infrastructure.
Leave a Reply to Todd3465Cancel reply
