Ask Hackaday: When Good Lithium Batteries Go Bad
Friends, I’ve gotten myself into a pickle and I need some help.
A few years back, I decided to get into solar power by building a complete PV system inside a mobile trailer. The rationale for this doesn’t matter for the current discussion, but for the curious, I wrote an article outlining the whole design and build process. Briefly, though, the system has two adjustable PV arrays mounted on the roof and side of a small cargo trailer, with an integrated solar inverter-charger and a 10-kWh LiFePO4 battery bank on the inside, along with all the usual switching and circuit protection stuff.
It’s pretty cool, if I do say so myself, and literally every word I’ve written for Hackaday since sometime in 2023 has been on a computer powered by that trailer. I must have built it pretty well, because it’s been largely hands-off since then, requiring very little maintenance. And therein lies the root of my current conundrum.
Spicy Pillows
I generally only go in the trailer once a month or so, just to check things over and make sure no critters — or squatters — have taken up residence. Apparently, my inspections had become somewhat cursory, because somehow I had managed to overlook a major problem brewing:
Chest burster much? I found this swollen mass of steel and lithium inside my trailer, ready to wreak havoc.
This is one of two homebrew server rack battery modules I used in the trailer’s first battery bank. The LG-branded modules were removed from service and sold second-hand by Battery Hookup; I stripped the proprietary management cards out of the packs and installed a 100-amp BMS, plus the comically oversized junction box for wiring. They worked pretty well for a couple of months, but I eventually got enough money together to buy a pair of larger, new-manufacture server-rack modules from Ruixu, and I disconnected the DIY batteries and put them aside in the trailer.
Glass Houses
While these batteries work fine for what they are, I have to admit that their homebrew nature gnawed at me.As for what happened to these batteries (while not as dramatic, the case on the other one is obviously swelling, too), I’m not sure. There was no chance for physical damage inside the trailer, and neither battery was dropped or penetrated. Whatever happened must have been caused by normal aging of the 28 pouch cells within, or possibly the thermal swings inside the trailer.
Either way, some of the pouches have obviously transformed into “spicy pillows” thanks to the chemical decomposition of their electrodes and electrolytes, creating CO2 and CO gas under enough pressure to deform the 14-gauge steel case of the modules. It’s a pretty impressive display of power when you think about it, and downright terrifying.
I know that posting this is likely going to open me up to considerable criticism in the comments, much of it deserved. I was clearly negligent here, at least in how I chose to store these batteries once I removed them from service. You can also ding me for trying to save a few bucks by buying second-hand batteries and modifying them myself, but let those of you who have never shaken hands with danger cast the first stone.
To my credit, I did mention in my original write-up that, “While these batteries work fine for what they are, I have to admit that their homebrew nature gnawed at me. The idea that a simple wiring mistake could result in a fire that would destroy years of hard work was hard to handle.” But really, the risk posed by these batteries, not just to the years of work I put into the trailer, but also the fire danger to my garage and my neighbor’s boat, camper, and truck, all of which are close to the trailer, makes me a little queasy when I think about it.
Your Turn
That’s all well and good, but the question remains: what do I do with these batteries now? To address the immediate safety concerns, I placed them at my local “Pole of Inaccessibility,” the point in my backyard that’s farthest from anything that might burn. This is a temporary move until I can figure out a way to recycle them. While my city does have battery recycling, I’m pretty sure they’d balk at accepting 90-pound server batteries even if they were brand new. With obvious deformities, they’ll probably at least tell me to get lost; at worst, they’d call the hazmat unit on me. The Environmental Protection Agency has a program for battery recycling, but that’s geared to consumers disposing of a few alkaline cells or maybe the dead pack from a Ryobi drill. Good luck getting them to accept these monsters.
How would you handle this? Bear in mind that I won’t entertain illegal options such as an unfortunate boating accident or “dig deep and shut up,” at least not publicly. But if you have any other ideas, we’d love to hear them. More generally, what’s your retirement plan for lithium batteries look like? With the increased availability of used batteries from wrecked EVs or even e-bike and scooter batteries, it’s a question that many of us will face eventually. If you’ve already run up against this problem, we’d love to hear how you handled it. Sound off in the comments below.
65 thoughts on “Ask Hackaday: When Good Lithium Batteries Go Bad
  1. The ‘POS’ sticker on that battery does seem accurate, at least! ;)
    As for what you should do… I think you said it in the last paragraph. At the very least, I don’t think you’d lose anything by seeing if they’d accept the batteries for recycling, other than a little time – the absolute worst they can do is to say ‘no’.
  2. Not sure where you live, but you might want to check with your municipality. Mine has an event a couple of times a year where they will take all manner of hazardous waste off your hands, and I think that does include batteries.
  3. More generally, what’s your retirement plan for lithium batteries look like?
    Slavia 634 pellet gun. Then Fiskars e-tool to bury them.
    1. If you have to dispose of lithium batteries you first need to discharge them. Get a bucket or pan that will fit the cells plus a whole lot of water and add salt or baking soda so the water is conductive. Throw the cells in the water and leave them 24 hours. They will bubble from the negative pole and the positive pole will dissolve but that normal. When they stop bubbling they’re discharged and safe from starting fires. In my area they go to the hazardous household chemical place instead of the landfill after discharging. Oh yea, you dont have to, but your probably gonna want to put your bucket outside while discharging.
      1. No. Let’s kill that salt water myth once and for all. it’s not a good idea to do that, because there is a real chance that. you end up with cells that look discharged, but are not.
  4. I’d call them and tell them you’re a consumer, have a bunch of batteries that are EOL and if you can bring them. Here in the EU, to prevent worse(i.e. you dumping them off the side of the road), the recycling places have to accept whatever you bring. It’s different when you’re a company. Then they will have a rate XXX per kg that you have to pay for them to accept the stuff.
    1. That wasn’t the case for my local ‘recycling centre’ here in the UK at least, which should still be by the rules much the same if not stricter than the EU. They might technically be obliged to, but wouldn’t actually do so in practice…
      Still it is the right move to try and get them into the battery recycling waste stream before doing anything else.
      1. Yeah I have a few lithium batteries (EG from a laptop or other device – nothing controversial) and can’t find any sensible way to properly dispose of them in my local area.
        The local tip took a couple of things with batteries inside (eg toothbrush) but it didn’t seem like they had any real mechanism for dealing with them, they were just kinda throwing them in the small appliances bin and ignoring the battery issue.
        1. Indeed, might just be who’s working that day not actually knowing. Or simply the day I turned up they didn’t actually have the battery bin available with a poor communicator so it sounded like a universal no rather than ‘oops sorry can’t today’
  5. My local transfer station has a battery recycle program, I’ve taken a lot of LiIon cells there and while they gave me their best grumpy faces they’ve always taken them
    I actually think they were grumpy because instead of hanging out inside the shed doing naff all they actually had to work to pack them up for transit.
    I always kill the cells with a giant resistor before I take them in.
  6. Y’know, I have the same kind of question about lots of things that are supposed to be properly disposed of, and which I’d like to handle appropriately if that is an option:
    Fluorescent bulbs usually contain mercury, and are supposed to be “properly disposed of” — Around here (semi-large city!) there’s like one store 30 minutes away that will take T8 / T12 tubes for a couple bucks each, and then hopefully do something with them other than pocket the money and toss them in the dumpster out back.
    I recently learned that PCBs (the polychlorinated kind, not the printed circuit kind) aren’t just a concern with utility-scale transformers — there’s also PCB containing capacitors and fluorescent ballasts. But, the official guidance on PCB containing materials is really only applicable to large companies (things like “contain them in a dedicated 50-gallon drum for disposal with your contracted PCB disposal firm”); what’s a hobbyist with a few old capacitors or a homeowner with a few old fluorescent fixtures supposed to do?
    E-waste in general, of the electronics hobbyist sort rather than the occasional complete computer sort — Municipal “computer round up” day around here is for computers as unit, not for a box of old circuit boards.
    And that’s not even getting into things that may be radioactive, etc!
    The core issue seems to be that there’s no or very little full-lifecycle management for things that are potentially hazardous at end of life. The original manufacturers are not forced to consider EOL, so they limit their liability by slapping a sticker that says “dispose of properly” and wash their hands of the matter, even if “properly” is not an option that exists.
    1. In my neck of the woods large supermarket chains are required by law to accept (for free) discarded batteries and lamps (fluorescent and LED), and to have them inserted into the recycling chain. All of them have collection points for the stuff, and most hardware stores do so as well. I usually keep them until I have a bundle, and they off they go with the next groceries run.
      At my daughter’s school they have a collection day about three times a year where all manner of electronics, old appliances, etc. can be dumped and it will be handled appropriately. There are city collection points as well, but the school is just a couple blocks from home, so it’s more convenient.
  7. do what the bomb squad would do, detonate them in a controlled manor. at least that’s how i deal with swollen cells.
    i have a lot of 18650 cells i need to get rid of. they are a very old at this point, none too useful, but most still carry a charge. im not sure if i should just hook them up to a resistor to discharge them down to zero over a long period of time such that they can be thrown away without sparking. our town does not have battery recycling at all. my first concern is getting them out of the house so they dont start a fire.
    1. I tape the ends and take mine to a battery recycling shops, I’ve collected loads of old 18650,s and use them in my House for various things because they last, I’ve not had any incidents except once when I over soldered and shorted which gave me a scare, just left that in the garden rain to destroy/flatten itself. Maybe I should rethink reusing these as it does make me nervous, I tend to use ones that come out of proper equipment eg handheld devices laptop’s drill’s etc, what do you think?
  8. UK here, at least in my borough, I can dispose of pretty much any battery at my local recycling centre and they’ve never turned down (or even checked) moderate sized Li-Ion cells.
    Not sure if they’d balk at those beasts but I’m also fairly sure they’d not even ask so it would be OK.
    Maybe if I was in a different country I’d see if there’s a recycling program for EV cells?
  9. If i’m understanding the narrative, they puffed up because you stopped using them. Once they deep discharge and sit on a shelf for a year, they all seem to puff up in my experience.
    They’re relatively benign if they’re discharged, so that’s my first step. Make sure they’re fully discharged. I like to leave an LED on my old packs to drain them, but if there’s any juice at all left in your pack you’ll probably want more current than that :) Not sure if your architecture means you’re gonna have to test / discharge each cell separately or if you can do the whole pack at once.
    Once they’re discharged, do whatever. I really don’t know how the municipal dump handles these things because if you bring the fully charged but puffed batteries, it’s a real time bomb. But if they’re discharged, no reason not to take the whole pile.
    Anyways i would have thought the point of putting it in an outbuilding is that you are accepting the fact it’ll burn down someday :)
    1. I use salt water on my dead RC batteries. Obviously, it’s a bit easier with these, as every cell has an external connection to both + and – for charging (no BMS). Provided you can expose all the cell terminals to a saltwater bath, they should all discharge just fine. Might take a while with a biggie like that though.
      1. The salt water myth is a pretty bad idea as there is a real risk that you end up with cells with tabs corroded off and seemingly discharged, but in reality still very much charged, but they measure 0 volts when you try to probe the remains of the terminals.
  10. Call your local fire station
    I had a swollen e-step battery, looked up the non emergency number and called them
    They were happy to come by later that day and picked it up
    Turns out they prefer showing up before the whole thing goes up in flames
  11. It seems some of your conundrum as described rests on your assumption of who will or won’t take them rather than having actually called and asked. If so, that might be a good first step.
    1. I see the article as well as its main question as a thought exercise. “If you want to find the correct answer to a question, post the wrong answer on the Internet and let the nerds compete with each other to correct you.”
      In other words, Dan could have just called around, but then we wouldn’t be here talking about it and generating page views. ;-)
      1. The comments give an interesting spotlight on the topic from the point of view of the hackers around the world, how else could one get that?
  12. I don’t know where you’re at. I use calltorecycle.org who sends me this 5 gallon steel container full of vermiculite and I put industrial lithium batteries in it and ship it back. It’s a paid service, of course, but at least then they’re gone. CellblockEX I think is the ones I use. They have a separate process for smaller things like laptop batteries.
    1. An average person can’t carry a 90 pounds battery. And if 2 people were carrying an object into airport, they’d probably be stopped before they can get inside.
  13. chemically extract the lithium for reuse. I would assume this is the path that battery manufacturers want end users to do (unless they don’t care about the environment), or do they offer any alternatives?
  14. Dude, what are you doing with that much power? I’ve got one 84AH battery in mine, and it’s plenty for lights, phone charging, fan and occasional electric blanket to pre warm the bed, and never used more than 40%. How much do they weigh in ritual?
  15. A while back an older gentleman gave me a power bank with a 10000 mAh spicy pillow. I doubt he knew the dangers when he gave it to me. I took it home and took the battery out and set it aside until I knew what to do with it, but I had completely forgotten about it for several months. Later, i found it, thanked the heavens it hadn’t gone off, and decided for the time being putting it outside in the burn barrel would be best. (may I add that we haven’t burned anything in there in a while, and its tall enough to contain the fire if the battery goes off.)
    A few months later my dad ended up dropping his smartphone in the lawnmower, turning it into a spaghetti phone, and one night I noticed he had left the phone parts on his desk. I could smell the battery. Out in the burn barrel.
    Now there are at least four batteries in the burn barrel. This is the best solution I can come up with for now, and the whole issue has been frustrating. Everybody tells me to recycle but nobody tells you how. We are rural so i can’t just walk down to my friendly-neighborhood-hazmat-recyclers and take care of it. I might order a bucket from call2recycle and ask community members here if they have any puffy batteries that need recycled, cuz I certainly don’t have 11 pounds worth.
    I can’t believe nobody’s thought up a better solution. It’s 2025. (I had great hope for those Lithium Ceramic batteries GreatScott! showed a long time ago but of course they are unobtainium.)
    1. But people have thought of better solutions. Multiple recycling options have been brought up both in the article and the comments.
  16. In the US (at least in my area) the local Batteries+(Bulbs) franchise will take them will take them free of charge for disposal. I’ve taken both big SGM and Li-Ion packs to them and they don’t even blink.
  17. And they told me I was a grumpy old fellow for fearing embedded lithium batteries sitting past their date in all sorts of modern consumer devices.
  18. My current lithium ion disposal plan is to put them in a box for my children to inherit. Hopefully they will have easier access to battery recycling.
    Seriously though the local recycling centre is a good bet or Tesco have a battery-shaped barrel where they accept batteries with no human interaction… Unless it starts smoking I guess.
    1. One of the local tech stores here used to accept batteries…. Then there was a fire… now they don’t :(
      A local metal recycling place here has a little half size shipping container away from all their other buildings for battery recycling with bins for each type of battery.
      As thanks, I give them boxes of old copper cabling for free.
  19. I put a light load on my LiPo batteries and run to 0V. cut the leads off, ready for disposal. Then either toss in the trash or if close to the recycle time (once a year) let them deal with it. My use is in R/C airplanes. A few times I kept the charge on it and at the club field, run a nail through it. Sometimes you get an impressive display of ‘energy’ as a reminder what you are working/playing with.
  20. In my I was able to take a batch of batteries of the definite 18650 Battery type to Staples of all places, plus the charger.
  21. At least it’s LiFePo4, that’s likely the only reason it didn’t catch fire. But sounds like those batteries might have had a defect (hence why LG or whatever got rid of them), or they got too cold. LiFePo4 might not ‘halt and catch fire’ like standard Lion, but they do expand when mistreated or faulty. I’ve learned that the hard way from low grade cells. Some LiFePo4 cell types will expand somewhat over their useful life (specifically the pouch type), and this is normal to a certain extent. But not like this. Low quality ones will expand more.
    This is also why pyramidal and (especially) cylindrical cells are much more common in larger, higher power battery packs as they are more highly expansion resistant due to the cell itself holding the pressure.
    Check local recycling centers, in the US, many will take Lion, for a fee usually.
    Also, general note for Lion: don’t set them on fire or dispose of them in trash, even if they are at 0v- they are still a major fire hazard and can still self ignite when fully discharged if they are punctured or crushed (like in a garbage truck). And they give off poisonous gas which goes without saying you shouldn’t breathe.
    1. But this does not necessarily mean the other (not so expanded) cells of the battery are actually bad, there just might have been one factory bad cell. If it is cold damaged though, then I’d consider using the other ones only after watching several power cycles and seeing if they expand or heat up unusually. All in all, LiFePo4 is rather robust.
    2. For Dan’s particular case, it’s probably a combination of elevated temperatures and over-discharge due to some quiescent current draw in his custom BMS (or even something parasitic). Those two can result in gas generation even though the cell is supposedly disconnected and being stored, and the cells may have remained fine if they were in service and the state of charge maintained above a critical level.
  22. The regional waste management authority usually rotates “hazmat disposal days” between towns’ or county recycling centers, scheduled every 2-3 months or more frequently in summer. A few calls or googling will reveal the schedule
  23. Over here if a city recycling place would not take them people would just dump them at the curb, at the place (hopefully) after hours, let the city deal with what they are suppose to deal with would be the thinking.
    Obviously the smart ones would remove identifying markers. But that’s not the vast majority, the rest when confronted would just lie and say someone stole them or some such.
    Is that a good thing? Yes and no, the city has responsibilities assigned to them by the government and international agreement in terms of recycling, and sometimes you have to force their hand if they don’t follow through and don’t do what the taxes pay them to do.
    The US of course is not the same as the EU, so I get it if this does not apply.
    I’m sure Tr*mp scoffs at recycling and mocks orgs and cities that have a program.
  24. First thing to do is discharge the batteries. Once they get below 50% charge they will be defanged. Fire is caused by the stored energy, not the lithium ions and discharging the batteries means they won’t have enough energy to start a fire. Then the internal materials and electrolyte are flammable which keeps the fire going.
    Once you do that, they are remarkably safe to handle. Even if you puncture the cells you will vent gas and that’s it. Of course, keep away from flame. Then recycle at any facility that can recycle batteries.
    1. The materials inside can ignite when exposed to air and humidity – it’s not just the charge left in the battery that can ignite it. They also generate gases like hydrogen, so leaving a damaged lithium battery in an enclosed space – even if fully discharged – is a bad idea.
  25. A tub large enough to submerge the entire unit.
    1 cup of salt (NaCl) per 10 litres of water, dissolve thoroughly.
    Submerge unit in brine for 2-3 days.
    Advice from Queensland Fire and Emergency Services:
    “If safe to do so, damaged lithium-ion batteries may be de-energised before disposal by placing in a large bucket filled with 10 litres of water containing 1 cup of table salt (sodium chloride) for 48 hours. This should be done outdoors in a well-ventilated area.”
    In other words, SALT WATER, STAT!
    1. The salt water myth just won’t die… It’s a pretty bad idea to corrode away the cell terminals before it’s actually discharged.
  26. US here.
    I have a battery store a couple blocks from my workplace that accepts dead batteries for recycling. For free! I’ve never found them to have a problem with anything I bring. If it’s a battery they will recycle it. So.. I would just take them to the local recycler you mentioned and give it a try.
    I also have a battery store about the same distance as that one is from work but from my house. That one is kind of expensive. Point being… if the first place you try is expensive don’t just assume they all are, check around.
  27. Get a 5 gallon bucket, lube it up with a little waste motor oil. Now fill the bucket with concrete, and as you are filling it up drop your junk lithium batteries in here and there. Near the top, embed a loop of steel cable for a handle. Let it cure for a day then dump the concrete block out. Now you have a nice 100 pound weight for holding down a tent, the bed of your snowplow, etc – and your batteries are safely stored “forever”.
  28. I hate lithium batteries, such an evil tech in practice. Every discarded vape slowly breaking down by the side of the road is a bushfire waiting to happen. Sure blame it on the stupid humans who litter, and watch them do it anyway. We need battery tec that simply does not burst into flames under any reasonably expected circumstance.
  29. Fire is a chemical process. If they want to burn, let them burn.
    Or dump them into hydroflouric acid and precipitate the benign constituent elements.
  30. I would check with a nearby metal recycling facility. You know, copper wire, junk steel.
    My nearest one will buy old lead acid, sealed, UPS batteries. I have not yet tried lithium cells.
  31. Chemistry relies on careful use of language. Presenting LiFePO4 as LiFePo4 (that 4 should be a subscript) transmutes the phosphorus+oxygen (phosphate) into polonium, atomic number 84. Who amongst us could possibly be unfamiliar with the entire list of chemical elements? We all sang along with Tom Lehrer, right?
    We’ll leave the spelling of fluoride for another time.
Leave a Reply to That's on a need to know basisCancel reply
