Meet The Shape That Cannot Pass Through Itself
Can a shape pass through itself? That is to say, if one had two identical solids, would it be possible to orient one such that a hole could be cut through it, allowing the other to pass through without breaking the first into separate pieces? It turns out that the answer is yes, at least for certain shapes. Recently, two friends, [Sergey Yurkevich] and [Jakob Steininger], found the first shape proven not to have this property.
A 3D-printed representation of a cube passing through itself [image: Wikipedia]
Back in the late 1600s, Prince Rupert of the Rhine proved it was possible to accomplish this feat with two identical cubes. One can tilt a cube just so, and the other cube can fit through a tunnel bored through it. A representation is shown here.
Later, researchers showed this was also true of more complex shapes. This ability to pass unbroken through a copy of oneself became known as Rupert’s Property. Sometimes it’s an amazingly tight fit, but it seems to always work.
In fact, it was so difficult to find candidates for exceptions to this that it was generally understood and accepted by mathematicians that every convex polyhedron (that is, every shape with flat sides and no holes, protrusions, or indentations) would have Rupert’s property. Until one was found that did not.
Noperthedron pencil holder
The first shape proven not to be able to pass through itself — known as the Noperthedron — is a vaguely ball-like shape, with a flat top and bottom. A fan has already added a cavity to create a 3D-printable pencil holder version of the noperthedron (shown here) if you want your own.
There are other promising candidate objects (they are rare) that may also lack Rupert’s property, but so far, this is the only proven one.
Shapes with unusual properties are interesting, and we love how tactile and visual they are. Consider Penrose tiles, a tile set that can cover any size of area without repeating. For decades, the minimum number of tile shapes needed to accomplish this was two. Recently, though, the number has dropped to one thanks to a shape known as “the hat.”
21 thoughts on “Meet The Shape That Cannot Pass Through Itself
    1. Answering my own question. I guess the problem is describing the object as a “shape” (per HaD), rather than “polyhedron” (the paper).
      While a a sphere cannot pass through itself, a sphere is also not polyhedron, and does not count in this case.
      Here’s a link to the paper, which was useful in answering this: https://arxiv.org/pdf/2112.13754
      HaD should probably include something about that, since “identical solids” and “shape” doesn’t accurately describe what the paper is really about.
      Sorry for the pedanticism.
      1. The paper you linked to is interesting and good background but I think the one claiming to prove that a polyhedron is nonRupert is this one
        https://arxiv.org/abs/2508.18475v1
        They slightly generalize the idea of being rupert in the abstract also but very quickly only talk about polyhedron. Probably the source of the confusion in this summary.
        I had the same question about the sphere as you.
    1. It’s unnecessarily confusing but the actual shape does not have the hole in the middle. That is the pencil holder version of the shape. It is the multifaceted sides with flat top and bottom.
  1. I see this as the Flatland problem. Even though the hole through the three-dimensional object has depth, it is uniform and effectively a two-dimensional plane as far as the inserted object is concerned for the purposes of traversal.
  2. Reminds me of the quarterfoil just to say plainly, in my opinion when you draw a quarterfoil in just lines you can intersect the lines to make shapes likes these with no effort. I like to call it gods eye.
Leave a Reply to NathanCancel reply
