The Key To Plotting
Plotters aren’t as common as they once were. Today, many printers can get high enough resolution with dots that drawing things with a pen isn’t as necessary as it once was. But certainly you’ve at least seen or heard of machines that would draw graphics using a pen. Most of them were conceptually like a 3D printer with a pen instead of a hotend and no real Z-axis. But as [biosrhythm] reminds us, some plotters were suspiciously like typewriters fitted with pens.
Instead of type bars, type balls, or daisy wheels, machines like the Panasonic Penwriter used a pen to draw your text on the page, as you can see in the video below. Some models had direct computer control via a serial port, if you wanted to plot using software. At least one model included a white pen so you could cover up any mistakes.
If you didn’t have a computer, the machine had its own way to input data for graphs. How did that work? Read for yourself.
Panasonic wasn’t the only game in town, either. Silver Reed — a familiar name in old printers — had a similar model that could connect via a parallel port. Other familiar names are Smith Corona, Brother, Sharp, and Sears.
Since all the machines take the same pens, they probably have very similar insides. According to the post, Alps was the actual manufacturer of the internal plotting mechanism, at least.
The video doesn’t show it, but the machines would draw little letters just as well as graphics. Maybe better since you could change font sizes and shapes without switching a ball. They could even “type” vertically or at an angle, at least with external software.
Since plotters are, at heart, close to 3D printers, it is pretty easy to build one these days. If plotting from keystrokes is too mundane for you, try voice control.
11 thoughts on “The Key To Plotting
  1. Back in the late 70’s I ran a test fixture that was composed of a commodore PET, an HP SCR meter, and an HP printing plotter, the fixture was used to test L-network antenna tuners for radio ranging and surveying equipment.
    The HP was a flatbed type, used a static charge to hold down the paper, and drew, and wrote on it with a pen…. it was much quieter than the Panasonic plotting printer….. and you had a choice of several different colors of ink to use.
    1. I spent some time playing with a vinyl cutter as a plotter, but found the subset of supported HPGL commands was vastly simplified, really just lines. The repeatability over large distances also wasn’t amazing, with errors building up over time. That was made worse by the fact that Inkscape has no path optimizations. Fine for cutting out big letters or simple shapes in vinyl, but not great for floor plans.
  2. I have always wondered how good plotters are for text? I mean I would assume unlike printers they cannot make “dots” well since they require their pen tips being moved to actually draw so stationary things like dots etc cannot be done well?
    1. Plotters can do text very well. Rotring, the company that made drafting pens and technical drawing equipment also made a small XY plotter specifically for lettering drawings called the Rotring NC-Scriber. It had a rubber keyboard, LCD display and used a Rotring pen. It fitted to a drafting table T-square:
      https://archive.org/details/nc-scriber-cs-100
      I had no idea these devices existed until I picked one up at a flea market a few months ago. Mine is missing the power unit but I have acquired the required 7-pin DIN plug and hope to power it up sometime.
  3. Actually, even though ALPS make all of these mechanisms, they don’t all use the same pens. There are to my knowledge, two different sizes. the typewrites and printers use a larger pens and mechanism than the smaller computer printer-plotter and calculator plotter type mechanism.
  4. My memories of pen plotters are mostly unpleasant. On small, dense multi-color plots the ink would soak and swell the paper so that the rotring metal tip pens ripped the paper when multiple passes went over the same spot. Using mylar instead of paper wore down the tips so fast that a thin line became a smudge before the job was done. More expensive ceramic tipped pens were available, but my recollection is that they still weren’t durable enough for large prints on mylar.
    This was a grit-wheel plotter capable of plots at least 3 feet wide. Fun to watch it in action.
Leave a Reply to forty-2Cancel reply
