We have to admit, we didn’t know that we wanted a desktop electric jellyfish until seeing [likeablob]’s Denki-Kurage, but it’s one of those projects that just fills a need so perfectly. The need being, of course, to have a Bladerunner-inspired electric animal on your desk, as well as having a great simple application for that Cheap Yellow Display (CYD) that you impulse purchased two years ago.
Maybe we’re projecting a little bit, but you should absolutely check this project out if you’re interested in doing anything with one of the CYDs. They are a perfect little experimentation platform, with a touchscreen, an ESP32, USB, and an SD card socket: everything you need to build a fun desktop control panel project that speaks either Bluetooth or WiFi.
We love [likeablob]’s aesthetic here. The wireframe graphics, the retro-cyber fonts in the configuration mode, and even the ability to change the strength of the current that the electric jellyfish is swimming against make this look so cool. And the build couldn’t be much simpler either. Flash the code using an online web flasher, 3D print out the understated frame, screw the CYD in, et voila! Here’s a direct GitHub link if you’re interested in the wireframe graphics routines.
We’ve seen a bunch of other projects with the CYD, mostly of the obvious control-panel variety. But while we’re all for functionality, it’s nice to see some frivolity as well. Have you made a CYD project lately? Let us know!
This doesn’t run on Android at all!
Just to be clear as mud, we are talking about the Nexus 6 kind of android here
you’re probably dreaming of your Android running electric sheep, not jellyfish
“a great simple application for that Cheap Yellow Display (CYD) that you impulse purchased two years ago”.
I feel seen. Now I have to build this.
Done! It’s cool!
Dang, that was fast! You beat me to it.
And yeah “you impulse purchased” might be a bit of poetic license.
In case anyone is like me, it’s called a Cheap Yellow Display (CYD) because the PCB the display is connected to is quite yellow.
Perfect for old NBC programming
