The Most Secure, Modern Computer Might Be A Mac
The Linux world is currently seeing an explosion in new users, thanks in large part to Microsoft turning its Windows operating system into the most intrusive piece of spyware in modern computing. For those who value privacy and security, Linux has long been the safe haven where there’s reasonable certainty that the operating system itself isn’t harvesting user data or otherwise snooping where it shouldn’t be. Yet even after solving the OS problem, a deeper issue remains: the hardware itself. Since around 2008, virtually every Intel and AMD processor has included coprocessors running closed-source code known as the Intel Management Engine (IME) or AMD Platform Security Processor (PSP).
M1 MacBook Air, now with more freedom
These components operate entirely outside the user’s and operating system’s control. They are given privileged access to memory, storage, and networking and can retain that access even when the CPU is not running, creating systemic vulnerabilities that cannot be fully mitigated by software alone. One practical approach to minimizing exposure to opaque management subsystems like the IME or PSP is to use platforms that do not use x86 hardware in the first place. Perhaps surprisingly, the ARM-based Apple M1 and M2 computers offer a compelling option, providing a more constrained and clearly defined trust model for Linux users who prioritize privacy and security.
Before getting into why Apple Silicon can be appealing for those with this concern, we first need to address the elephant in the room: Apple’s proprietary, closed-source operating system. Luckily, the Asahi Linux project has done most of the heavy lifting for those with certain Apple Silicon machines who want to go more open-source. In fact, Asahi is one of the easiest Linux installs to perform today even when compared to beginner-friendly distributions like Mint or Fedora, provided you are using fully supported M1 or M2 machines rather than attempting an install on newer, less-supported models. The installer runs as a script within macOS, eliminating the need to image a USB stick. Once the script is executed, the user simply follows the prompts, restarts the computer, and boots into the new Linux environment. Privacy-conscious users may also want to take a few optional steps, such as verifying the Asahi checksum and encrypting the installation with LUKS but these steps are not too challenging for experienced users. Continue reading “The Most Secure, Modern Computer Might Be A Mac” →
Electric Motorcycles Don’t Have To Be Security Nightmares, But This One Was
Once upon a time, they told us we wouldn’t download a car, and they were wrong. Later, Zero Motorcycles stated in their FAQ that you cannot hack an electric motorcycle, a statement which [Persephone Karnstein] and collaborator [Mitchell Marasch] evidently took issue with. Not only can you hack an electric motorcycle, it is — in [Persephone]’s words — a security nightmare.
You should absolutely go over to [Persephone]’s website and check out the whole write-up, which is adapted from a talk given at BSides Seattle 2026. There’s simply way more detail than we can get into here. Everything from “what horridly toxic solvents would I need to unpot this PCB?” to the scripts used in de-compiling and understanding code, it’s all there, and in a lively and readable style to boot. Even if you have no interest in security, or electric motorcycles, you should check it out.
The upshot is that not only were Zero Motorcycles wrong when they said their electric motorcycles could not be hacked, they were hilariously wrong. The problem isn’t the motorcycle alone: it has an app that talks to the electronics on the bike, which take over-the-air (OTA) updates. What about the code linked to the VIN alluded to in that screenshot? Well, it turns out you just need a code structured like a VIN, not an actual number. Oops. By the end of it, [Persephone] and [Mitchell] have taken absolute control of the bike’s firmware, an so have them full control over all its systems.
Why cut the brake lines when you can perform an OTA update that will do the same thing invisibly? And don’t think you can just reset the bike to factory settings to fix it: they thought of this, and the purely-conceptual, never-deployed malware has enough access to prevent that. Or they could just set the battery on fire. That was an option, too, because the battery management system gets OTA updates as well.
To be clear, we don’t have any problem with a motorcycle that’s dependent on electronics to operate. After all, we’ve seen many projects that would meet that definition over the years. But the difference is none of those projects fumbled the execution this badly. Even this 3 kW unicycle, which has a computer for balance control, doesn’t see the need to expose itself. It’s horribly unsafe in very different ways.
You Can Now Run MS-DOS Applications On The Apple IIe
After a lot of debugging, [Seth Kushniryk] has managed to get the last issuess shaken out of his port of MS-DOS 2.0 to the Apple II, and has released the project to the public. If you have the requisite AD8088 or similar co-processor expansion card with onboard x86 CPU, this should be all you need to get started.
Although this co-processor card contains effectively a self-contained x86 system, its only I/O goes via the expansion bus, so it has to play nice with the 6502 CPU of the Apple II system. When we last reported on [Seth]’s efforts he had just managed to get MS-DOS 2.0 booting and basically in a barebones working state.
Since then he’s been working on the bridge program that provides communication between the 8088 on the card and the Apple II’s 6502, relocating it in RAM to enable high-resolution graphics, as well as other tweaks and optimizations. Also a lot of bug hunting, including an undocumented ProDOS constraint with a request count.
With all of this done it’s now possible to run basically any MS-DOS 2.0 compatible software, assuming it doesn’t try to write directly to video memory. This does limit the software selection somewhat, but back in the day it would probably have been amazing to have that 8 MHz 8088 purring along the 6502 to run both Apple and DOS software titles. Props to [Seth] for restoring this software functionality that had been lost to the ages.
Continue reading “You Can Now Run MS-DOS Applications On The Apple IIe” →
