How Pizza Tycoon Simulates Traffic On A 25 MHz CPU
Although the gameĀ Pizza Tycoon – known as Pizza Connection in Europe – probably doesn’t ring a bell for many folk, this 1994 DOS title is special enough for [cowomaly] to write an open source engine to bring it into the modern age as Pizza Legacy. Along the way, some questions popped up, such as how to animate the little cars that you see driving around in the simulated city and how the heck this was done back in the day on a 25 MHz 386 CPU.
Continue reading “How Pizza Tycoon Simulates Traffic On A 25 MHz CPU” →
A Trackball 3D Controller
We use CAD packages in our 3D work, and it’s likely that many of us have become annoyed by the limitations of controlling the view of a 3D object using a 2D interface, our mouse. Joystick-like 3D controllers exist for this purpose, but [David Liu] found them inconvenient. He tried a trackball, but that didn’t improve matters. His response was to take the trackball and change the way it controlled the software, turning it from the equivalent of a ball rolling over a surface to a ball representing the object on the screen itself. He can turn and rotate the object intuitively just by moving the ball.
He started with a Kensington off-the-shelf trackball and adapted its electronics and handy twin optical sensors such that it worked in the required fashion. There was a lot of iterating and tuning to get the control feeling right, but he’s ended up with a peripheral that replaces both mouse and 3D joystick, and leaves the other hand free for those keyboard shortcuts.
Continue reading “A Trackball 3D Controller” →
