Sega Master System Controllers, Now With USB C
USB wasn’t even a gleam in an engineer’s eye when the Sega Master System hit the market in 1985. Today, we’re up to USB 4 or something, and the USB C connector is becoming a defacto standard for just about everything except desktop computers. [Retrostalgia] is embracing this by mating the control pad from Sega’s first international console with the connector of today.
Naturally, the Sega Master System did not use the Universal Serial Bus to talk to its controllers, so some conversion was in order. That’s achieved with the use of a RP2040 microcontroller, which reads the D-pad and action buttons via its GPIO pins. It then acts as a HID device when plugged into a computer or other USB host, showing up as a simple game controller. This is a particularly easy hack as the Master System controller is so simple, there’s no need to decipher any protocols or anything like that. It’s just about wiring up a few simple buttons. Beyond that, it’s just a matter of hot-gluing the RP2040 into the Master System controller housing, and making some room for the USB C port to sneak out the top. We’d have loved to seen a little extra hackery on this one, perhaps adding some rumble to a controller that was never, ever supposed to have it.
If you want to adapt authentic old controllers to work with modern computers and emulators, this project is a great place to start. It doesn’t get much simpler than the Master System, after all. You can always work your way up to more advanced feats later, like working with the beloved Wavebird. Video after the break.
Continue reading “Sega Master System Controllers, Now With USB C” →
Why Solid State Batteries Short
Solid state batteries, we are told, are the new hot battery technology that will replace lithium-ion batteries. Soon. Not that we haven’t heard that before. One reason it isn’t dominating the market today is that it’s prone to short circuits during charging. [Dr. Yuwei Zhang and others have published a paper detailing why the shorts happen, which could lead to strategies to improve the technology.
Solid state batteries employ a solid electrolyte and a lithium anode. It is known that, sometimes, lithium metal from the anode forms dendrites that penetrate the ceramic electrolyte and cause it to crack. This is somewhat of a mystery as the lithium is a soft metal: to quote [Zhang], “like a gummy bear”.
There were two leading hypotheses for the observations. [Zhang’s] team showed that hydrostatic stress made the lithium dendrites act like a water jet, enabling them to penetrate the hard ceramic.
There is still work to figure out what to do about it, but understanding the root cause is certainly a step in the right direction. We’ve looked at these batteries before. We’ve also seen how changing the anode construction might help with the problem.
An ultrasonic transducer with two wires attached to it by alligator clips floats very slightly suspended over a glass surface.
A Different Kind Of Ultrasonic Levitation
Ultrasonic levitation is by now a familiar trick: one or more ultrasonic transducers create a standing wave, and small objects can be held in the nodes of this standing wave. With a sufficiently large array of transducers, it’s even possible to control the movement of the object. This isn’t the only form of ultrasonic levitation, however, as [Steve Mould] demonstrated with his ultrasonic air hockey table.
This less familiar form of levitation was discovered by [Bob Collins] while working on torpedo guidance systems: when he tried to place a glass lens on an ultrasonic transducer it immediately slid off. He found during further experimentation that an ultrasonic transducer would levitate over any sufficiently flat and smooth surface. It works by trapping a very thin layer of air between the transducer and the smooth surface. When the transducer moves sharply toward the surface, it compresses a layer of air in between, and forces some air out, and the reverse happens while pulling back. However, during the downstroke, the gap through which air can escape is narrower than during the upstroke, and there is more surface-induced drag, meaning that the inflow and outflow of air through a narrow gap isn’t completely equal. At a certain distance, inflow and outflow balance, and the transducer floats on a thin layer of air. Continue reading “A Different Kind Of Ultrasonic Levitation” →
The Challenges Of 3D Printing Reliable Springs
Springs are great, but making them out of plastic tends to come with some downsides, for fairly obvious reasons. Creating a compliant mechanism that can be 3D printed and yet which doesn’t permanently deform or wear out after a few uses is therefore a bit of a struggle. The compliant toggle mechanism that [neotoy] designed is said to have addressed those issues, with the model available on Printables for anyone to give a shake.
The model in question is a toggle, which is the commonly seen plastic or metal device that clamps down on e.g. rope or cord and requires you to push on it to have it release said clamping force. Normally these use a metal spring inside, but this version is fully 3D printable and thus forms a practical way to test this particular compliant mechanism with a variety of materials.
The internal spring is a printed spiral spring, with the example in the video printed in PETG. You can of course also print it in other materials for different durability and springiness properties. As noted in the video, PLA makes for a very poor spring material, so you probably want to skip that one.
We covered compliant mechanisms in the past for purposes like blasters, including some that you can only see under a microscope.
Continue reading “The Challenges Of 3D Printing Reliable Springs” →
2026 Green Powered Challenge: Adding Low-Power Sleep To Microcontrollers
When building a project to operate on battery power for long periods of time, having a microcontroller with a reliable and extremely low-power sleep mode is critical. When processing power isn’t needed, it should be able to wait around using almost no energy until an interrupt triggers it. Once triggered, the CPU performs its tasks and then puts itself right back to sleep, making sure the battery lasts as long as possible. Unfortunately, not every microcontroller has sleep capabilities or has an acceptably low level of power use for maximizing battery life. For these systems, a tool like this power manager might come in handy.
Continue reading “2026 Green Powered Challenge: Adding Low-Power Sleep To Microcontrollers” →
Register Renaming
[Shreeyash] asks an interesting question: how many registers does your CPU have? The answer is probably more than you think. The reason? Modern CPUs — at least many of them — execute instructions out of sequence so they can perform multiple instructions per clock cycle. To do this, they may need to execute instructions that change registers that other instructions are still reading. In addition, you might be writing a result speculatively — a branch might make it where your result won’t wind up in the target register. The answer to both of these problems is register renaming.
The ARM CPU he looks at has many physical registers you can’t see. These get mapped to the registers you use on the fly. So when you read a register in software, you are really getting an underlying physical register. Which one? Depends on when you read it.
Continue reading “Register Renaming” →
Trying Pair Programming With An LLM Chatbot
When it comes to software developers, there are a few distinct types. For example, the extroverted, chatty type, who is always going out there to share the latest and newest libraries and projects with everyone, and is very much into bouncing ideas off others, regardless of whether they know what you’re talking about. Then there is the introverted loner, who prefers to tackle programming challenges by bouncing things around inside their own minds and going on long walks to mull things over before committing to anything significant.
This leads to interesting scenarios when it comes to management-enforced ‘optimization’ strategies, like Pair Programming. This approach involves two developers sharing the same computer and keyboard, theoretically doubling the effective output by some kind of metric, but realistically often leading to at least one side feeling pretty miserable and disconnected unless you put two of the chatty types together.
As a certified introverted loner developer, the idea of using an LLM chatbot as a coding assistant naturally triggers unpleasant flashbacks to hours of forced awkward pair ‘programming’. However, maybe using an LLM chatbot could be more pleasant because you can skip the whole awkward socializing bit. In order to give it a shake, I put together a little experiment to see whether LLM-based coding assistants is something that I could come to appreciate, unlike pair programming.
Continue reading “Trying Pair Programming With An LLM Chatbot” →
