How To Make Steel That Breathes
There are plenty of porous materials out there that we’re all readily familiar with. Fabrics and wood are great examples, allowing liquids or gases to pass through to a certain degree—a property which is useful or problematic depending on the application.
Metals, however, are not something we would readily consider to be porous. They are solid, unyielding, and impermeable. However, with the right techniques, it is possible to produce so-called “breathable” steel, which has particularly interesting applications in the molding industry.
Breathe Into Me And Make Me Real
Imagine you’re making tooling for an injection molding operation. You’re using steel, of course, because you need a hard, resilient material that can deal with the high temperatures and pressures involved. It’s tough, and readily able to be machined into the desired geometry for your application. Of course, it doesn’t let liquid or gas pass, since it’s a solid impermeable material. This means that when you inject your mold full of hot plastic, you need to find somewhere for the air inside to go. Otherwise, the gas in the mold will end up dissolved in the molten plastic, causing voids, surface imperfections, and other irregularities. Chasing away gas porosity defects in finished parts is one of the major jobs of casting engineers the world over, an endless battle against the forces of heat transfer and fluid mechanics.
Traditionally, this is deal by designing a mold with exhaust ports or vacuum hookups to allow the air to vent out as needed. This takes a great deal of work to get right, particularly when it comes to getting your defect rates as low as possible in mass production. If your gas can’t vent fast enough, or if there are areas where it gets trapped, you end up with defects, and you have to go back to the drawing board.
Breathable mold steel attempts to solve this problem by venting gas through the tooling itself. It allows the creation of a steel mold that is full of tiny little pores that allow air to pass through, while still acting largely impermeable to the molten plastic being molded.
Breathable mold steel is quite something to behold, behaving quite unlike a normal steel part in this regard.
As you might imagine, it’s quite difficult to make a steel mold with complex geometry that also has lots of tiny contiguous holes that allow gases to pass through. It is possible, however, by using some tricky additive manufacturing techniques.
By mixing a foaming agent into powder metal for selective laser melting (SLM) printing, it’s possible to generate interconnected micrometer-scale pores in steel that allow it to ‘breathe’. The pores are generated by the gas released during the heat-based decomposition of the foaming agent. Credit: research paper
As outlined in one research paper, it’s possible to produce breathable steel via selective laser melting (SLM) 3D printing techniques. This involves using a high-powered laser to fuse metal powder together, layer by layer, to produce a final part. Combining a foaming agent with the metal powder enables the creation of 3D-printed metal parts with incredibly fine interconnected pores.
The pores need to be particularly small, on the order of 80 micrometers or less, such that they allow gas in the mold to pass freely while blocking the flow of the larger polymer molecules of the injected plastic.
Chromium nitride is one foaming agent typically used, for the fact that the Cr and N released during its decomposition both lend beneficial properties to the steel of the finished product. The foaming agent is mixed in with the steel powder, and melts along with it as the part is being produced. The breakdown of the foaming agent releases gas bubbles which creates pores in the steel part as it is produced in a relatively predictable manner.
Microscope images of breathable steel samples produced with 3% CrNx and 5% CrNx foaming agent, respectively. Credit: research paper
The level of porosity can be controlled by the amount of foaming agent mixed in to the steel powder, as well as the laser settings. Lower melt pool temperatures caused by faster scanning speeds or lower laser powers tend to favor more porous structures, due to the fluid mechanics involved and how the cooler liquid steel flows into existing pores.
There have been earlier attempts to vent molds with special breathable steel inserts in the past. These consist of premade rectangular inserts or round bars which have been made with so-called “ventilated steel” like PM-35. This material is made by sintering steel powders together in such a way to create a porosity of 20-30%. However, this process isn’t always great for advanced geometry that one might find in a injection mold. Thus, the creation of breathable rods and bars that can be used as an insert in a larger mold, acting as a localized vent. It’s a useful technique, but comes with more constraints on mold and part geometry than being able to simply create the whole mold itself out of breathable steel.
Micro-CT images of a breathable steel sample. Credit: research paper
There are other powder metal techniques that allow the production of more complex vented parts, but they can be expensive and difficult to execute well down to smaller pore sizes, especially compared to the simplicity of SLM printing with an additional foaming agent. The 3D-printing based process has also proven to have more admirable mechanical properties compared to products like PM-35 steel in some cases, with impressive compressive strength as well as hardness and corrosion resistance.
Breathable steel is probably not something you’ll come across in your everyday life unless you happen to work in particular manufacturing fields. Still, if you have the expensive 3D printing hardware on hand to work with metal powders, and you really want to make a complex metal part that’s also porous, this is a great way to go. You could probably use it to make some very weird magic tricks at the very least. Ultimately, it just goes to show that modern material processing techniques can upend everything we think we know about a common material like steel. It’s amazing what can be done!
15 thoughts on “How To Make Steel That Breathes”
  1. I have some sintered brass air filters that are absolutely beautiful, but as noted in the article, the pore size is too large to prevent intrusion by molten plastic during injection. Early metal 3d prints were done, I believe, by hot isostatic pressing that resulted in a solid that had a lot of porosity and this was followed by vacuum filling the shape with bronze that wetted the internals and made a zero porosity alloy. That makes me wonder if HIP could do something similar to this using established manufacturing, but again, maybe the pore size is wrong.
  2. I’d assume that you can keep something expensive like an injection mold in a controlled environment(or at least one controlled against things other than whatever you are molding); but I’m curious how much of an effect this has on corrosion sensitivity.
    In a lot of contexts all that delicious surface area just cries out for anything thermodynamically plausible to start happening to you significantly faster than it would to a bulk chunk. Steel certainly isn’t the worst offender; but iron fundamentally isn’t all that stoic and that jumble of chemically varied regions seems like a near perfect assurance that if there’s a level of chromium or nitrogen that isn’t a helpful alloy it will exist somewhere in the foam.
  3. Breweries use stainless steel “carbonation stones”, which are 304 or 316 grade stainless powder that’s been sintered via compression in an oven. Ours was a a 6 inch rod that poked into the bright tanks near the bottom. Some systems use a smaller stubby in line stones so they can carbonate as they transfer to kegs.
    Never occurred to me to use it as part of an injection mold, but now I kind of want laser sintered brew stones just for the cool factor.
  4. As microgravity environments become more accessible and economical, would the production of larger sintered/foamed objects become feasible? The savings in mass, as well as in raw material, might make them applicable for aerospace use.
    1. I remember seeing something similar but instead of using a foaming agent they used hollow metal spheres in various materials. It made the part quite a lot lighter and had some mechanical advantages too.
  5. With larger porosity and or simply printed/ planned pores… and bounded cross sections, this metal foam would be ideal for liquid and air heat exchangers. Likely achieve much higher efficiency than current conventional hrvs ever dreamed of. The special properties are not lost on me… there are existing processes that could just as well serve the purpose I’m describing…. but interesting to consider.
  6. Why can’t mold machines run in a small vacuum chamber so there isn’t any air to cause issues to begin with?
    1. It’s not cost-effective.
      Commercial injection molding machines are large, the volume of air to pump down is huge and would require many minutes to pump down. An injection cycle is mere seconds, not minutes.
      Source plastic is added and finished product is removed each cycle, requiring a pump-down cycle each time.
      It’s not just air in the mold. Some gasses come from the heated plastic itself.
  7. Poor man version – get some loose carbon fibers, steel wool or even some activated carbon felt and electroplate it. Caveat – when in a big ball, center will electroplate poorly. You can 3d-print a grid mold so that it holds shape.
  8. This with finer pores (for water-based liquids) could also have applications in chemistry. Or highly effective catalysts.
  9. Is that an intentional “View This Post on Instagram” in the middle of the article or am I being blocked from Instagram viewing for not allowing tracking?
  10. Of note: sintered aluminum is already used extensively in lower-precision molding operations.
    We built tooling for vacuum-forming plastic out of sintered aluminum many years ago. It cuts nicely on a CNC, holds more than enough detail, and of course provides the requisite suction to help the material form well-defined features.
  11. Did I miss where it was discussed or is there a technique missing? The bulk metal material can have much larger porosity than necessary, you simply need the interfacing material between the mold and the plastic have the specific porosity.
    So the bulk of it can be a simpler process like a foam or large pore sintering and then you just slap on (via appropriate process) a solid layer/foil or mesh that give you the impermeable to plastic characteristic layer you need only at the interface. I think the balancing act would be between how thick you can make the interface for mold longevity and the degree you lose uniformity in the pore as the thicker material interferes with itself. Part of the mold design already involves fillets and chamfers and that would leverage easily into avoiding the bad scenarios of applying a film/foil/mesh layer.
    My imagination suggests there’s a sweet spot of “good enough” for use. Compared to getting the mold entirely perfect from surface to bulk material, it would seem easier to take a nice big CNC’d block of the big pore stuff and even in a tedious scenario someone has to do something similar to gold leafing the mold surface.
