Honda Civics And Installing Software With Android Test Keys
As more and more of the ‘smart’ infotainment systems in cars begin to age out of support, it becomes increasingly more relevant to figure out how to do something with that lump of computer-and-display sitting prominently in the dashboard.
Here [Eric McDonald]’s reverse-engineering of the 2012-era Android-based infotainment system in a 2021 Honda Civic is an interesting case study, with recently the discovery made that the head unit of these infotainment systems can be updated via USB by using standard Android Open Source Project (AOSP) test keys as these were left on the file system.
This is a nice update to his initial reverse-engineering back in the innocent days of 2023, when such a facepalm-worthy exploit seemed unimaginable, but then the ‘s’ in ‘infotainment’ has always stood for ‘security’. In this exploit that [Eric] calls the EvilValet attack, it means that anyone with physical access to the USB port inside the car can theoretically run arbitrary code signed with these test keys, as documented in the GitHub project.
So far this rather foolish security issue has only been confirmed on [Eric]’s 2021 Honda Civic, but considering how those – often third-party – infotainment systems tend to get reused and recycled across generations and car variants, it’s quite possible that more Android-based infotainment systems have this vulnerability.
This exploit is obviously a double-edged sword, as on one hand it’s great that an owner of one of these cars can now basically do whatever they want with said infotainment system, but on the other hand it means that anyone who slides into your car with a USB stick can do the same.
Bike-Powered Shredder Makes Short Work Of 3D Printer Waste
[Brogan M Pratt] and his students do a lot of 3D printing, and as such found themselves producing a lot of plastic waste. Seeing an opportunity, they built a bike-powered plastic shredder that turns a little human exercise into the power needed to transform waste plastic into small bits. Shredding plastic is a necessary first step for any sort of processing, so getting this part working reliably is as important as it is educational.
Shredding is a necessary first step to processing plastic waste.
Being in the Netherlands, using a bike makes perfect sense. But it turns out there’s a lot more to making a human-powered plastic shredder than simply bolting a sprocket to a shredder, looping the bike chain over it, then climbing on and working up a sweat.
In between the bike and the shredder is a large gear reduction, a fifteen kilogram flywheel, and a heavy-duty frame to anchor everything in the face of so much mass and torque. Add some covers and safety guards and the result is a stationary bike with a hopper for waste, a bin for output, and enough rotational torque and inertia to chew through stubborn bits without stalling.
Now that the shredder works, what’s the plan for all the little plastic shreds? The goal is to turn it back into usable filament which is obviously very useful, but we’ve also seen that compression molding plastic waste can work pretty well, too.
Being an educator, [Brogan] makes it clear that a bike-powered shredder, while pretty cool, is not the only missing link in sustainability. There is currently no easy way to recycle plastic at scale. But the shredder is a critical part of demonstrating the whole process in a hands-on way, and learning why recycling plastic at scale is a genuinely difficult job.
Continue reading “Bike-Powered Shredder Makes Short Work Of 3D Printer Waste” →
