The Physics Of Keeping Thermal Power Stations Cool
Recently thermal power stations have been in the news quite a bit, mostly in the context of them being throttled back or shut down due to the river water used to cool them either getting too warm or said river having dropped to a level where it can no longer provide cooling water. Obviously this is a problem, but it helps to understand how we got to this point and what can be done to fix it.
Thermal power stations – also called power plants – come in a wide variety of shapes and sizes, ranging from old-school coal- and gas-fueled power stations to modern nuclear power plants. Something like a concentrated solar power (CSP) station is also a thermal power station, as all of them have a heat source that’s used to generate electricity from, whether that’s a boiler, nuclear reactor core or a big vat of sodium heated up by the Sun via massive mirrors or oil-filled tubes in parabolic throughs.
Except for open-cycle gas turbines (OCGTs) – which are basically jet engines connected to a generator – this thermal energy is then used to generate steam that drives a steam turbine. Once most energy in the steam has been depleted, it has to be condensed back into e.g. water, so that it can be led back to the steam generator. How this condensing step is performed is the question here, with a number of methods available.
Continue reading “The Physics Of Keeping Thermal Power Stations Cool” →
A lightning strike is shown striking the ground at close range (fewer than thirty feet away).
Triggering Lightning With A Rocket
Lightning, despite being a common and readily-detected phenomenon, is nevertheless difficult to study. One reason is the difficulty of predicting when and where lightning will strike; tall structures do attract more lightning strikes, but it’s hard to move them into a storm’s path. Instead, researchers often use small rockets carrying a fine wire to trigger strikes, an approach [Electron Impressions] recently replicated (more details).
The science of this is less than straightforward: even in calm weather, there’s a surprisingly strong atmospheric electric field, about 100 volts per meter off the ground. During a thunderstorm, though, this can build up to kilovolts per meter, and may reverse polarity. When an updraft carries supercooled water, ice crystals, and graupel (ice particles formed by supercooled water freezing on a snowflake) upwards, the heavier graupel falls relative to the other components. As it collides with ice crystals, it builds up a negative charge and the crystals accumulate a positive charge; across a storm, this leads to positive charge building up near the top of clouds and negative charge near the bottom. Lightning equalizes this imbalance. In the relatively few cloud-to-ground strikes, a dielectric breakdown begins from both sides of the stroke, with leaders rising from the ground and descending from the cloud. The wire trailed by a rocket creates an artificial leader, ideally triggering a controlled strike.
To consistently get a strike, the rocket needs to be launched under a strongly-negatively-charged region of the cloud. An electric field mill measures the local field strength; these are usually quite expensive, but [Electron Impressions] managed to build his own. The rocket itself was 3D printed and designed to fly well under stormy conditions. It carried a strand of thin copper wire wound onto a plastic spool meant to minimize friction and prevent broken wires. The rocket’s igniter was waterproofed for storm conditions and remotely triggered using a walkie-talkie for safety.
After many attempts, [Electron Impressions] finally managed to trigger a strike and video the results. The first stroke created a plasma channel, along which several more strokes followed. This indicated that the cloud had probably been negatively charged, which was in agreement with the field mill’s measurements. The wind blew the plasma channel slightly to the side, where it caused a second rocket to explode on the ground. Both ignition systems were destroyed, and the remains of the rocket were never found. Sadly, the strike doesn’t seem to have formed a fulgurite, but it did fracture the ground as water flash-boiled.
For a more reusable solution, some researchers have also experimented with using drones to trigger lightning. There’s good reason for more study; the theory of lightning formation still has some major open questions.
Even On The Red Planet, Hexagons Are The Bestagons
Though their pure Platonic Forms may only exist in the world of ideas, certain regular shapes can’t help but keep falling out of natural processes– case in point, the six-sided solid we call a hexagon, which is indisputably the bestagon. Don’t take it up with us– start an argument with the God of War, because its his planet that’s showing off six sided features, dubbed “polygonal fractures” which NASA’s Curiosity rover is currently crushing under tread in Valle Grande. Now, you might look at the photos and say– well, that’s clearly a dried mudflat. Evidence of water! No brainier, let’s all get Nobel Prizes. Not so fast.
Nothing in nature is ever single-sourced or that simple; if you live somewhere you get dried mud, you may have seen such hexagonal features, but ask anyone from the land of the ice and snow and they’ll tell you that freeze-thaw or frost heave can bring a field of rigolith’s inner Catan board out as well. Sure, we usually call it “dirt” here on Earth, but it’s rigolith by any other name. So NASA isn’t jumping the gun, and their announcement conservatively says that they aren’t sure how the polygonal features formed. Which is both fair enough and very interesting, as figuring it out is going to give some clues into what was going on in this part of Mars in the geologically recent past, especially since this vast field of grid tiles stretches as far as the camera can see. The consensus is that Mars was once “warm and wet” but that’s a relative term– how warm, and how wet, are very much up for debate.
Speaking of crushing hexagons under Curiosity’s wheels– did anyone think said wheels would last this long? They were already tweaking the traction control to extend their life nine years ago. Between it’s plutonium power and ongoing software updates, its a fair bet that Curiosity will outlast the late, lamented Opportunity who currently holds the endurance record at 15 Earth-years.
